Motorola MB 511 hard reset Hello, Can you help me to make a hard reset in a motorola mb511, please ? Thanks. |
@ Adel_Khaled, Try to perform following procedures: 1. Power off phone. If it won’t turn off, take the battery out. 2. Press and hold the Power and Camera button at the same time. Release the Camera button when prompted. 3. Press Volume Down key. 4. Select option factory reset Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
Thank you for your help, but there is not a camera button. That's why i can't do your procedure. Have you an other idea, please ? Thanks. |
@ Adel_Khaled, What is wrong with the phone? Did you try to Press Menu -> Settings -> Privacy -> Factory Data Reset. Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
Hello. I have bought a mb511 unlock code but when i enter it on the phone it doesn't work. It says that the unlock request has failed. Then i want to make a hard reset and retry. I have already pressed Menu -> Settings -> Privacy -> Factory Data Reset. Is it a hard reset ? Thanks. |
Factory Data Reset will clear the phone's memory and put the phone back to the original factory default state. Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. |
1. Hold POWER BUTTON and X button on keyboard 2. After logo popup release POWER BUTTON and keep hold just X button 3. Triangle with little android popup release X button 4. Press POWER BUTTON once Popup screen : Android System Recovery <2e> Android System Recovery Utility Reboot system now Apply SDcard update.zip Wipe data/Factory reset Wipe cache partition |
Hi! I need to unlock a flipout too. Do you know if it can be done? Any place to reommend to get the code? Thanks in advance, Kamel |
@ DrKamel, This phone model is not currently supported for unlock procedure. Best Regards GSMServer team http://www.gsmserver.com/img/sc_userbar_1.png |
I bought unlock MB511. Only my concern is, after hard reset, The My MB511 will be still unlock, or going to locked. Just I like to remove some AT&T add and application. May be I'm wrong to do this way. Another way, I can not download and install "Sideload Enabler for Backflip. Each time going to downloading and later Shaw me "did not find application".That was in so different sides, android application down loader. Peter. |
good job..getting new ideas frm forum:) |
good job bro nice post |
thx Quote:
Thanks somat***** is working..... |
