03-07-2006, 16:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In My Pub
Member: 307549 Status: Offline Thanks Meter: 188 | V547 stuck in bootmode??? It reads as BOOT LOADER 07.E0 SW VERSION: NO FOUND I hvae full flashed the phone but still the same thing, and i can not repair the PDS all i get is error 9B? Can anyone say how is the best way to fix this? Thank Simz |
03-08-2006, 05:30 | #3 (permalink) |
No Life Poster Join Date: Nov 2004 Location: Capetown
Member: 91045 Status: Offline Thanks Meter: 8,696 | Bro got Same problem on One V300 here Full flashed even With TP but still Same in Bootloader when insert battery....PDS repair cant be done...SO We both r in Same Prob...Can anyone Suggest us a Working TIP |
03-08-2006, 20:08 | #6 (permalink) | |
Member: 307549 Status: Offline Thanks Meter: 188 | Quote:
That could be your pc mate, as i could repair the pds but half way through it, it would stop adn i got error 9B in smartmoto. | |
03-09-2006, 14:45 | #7 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello Simzmobiles, Probably You have used repair cable (force boot mode cable) during Repair PDS procedure.You should use standard cable, make Repair PDS and than make a full flash. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-09-2006, 14:56 | #8 (permalink) | |
No i never used the repair cable, i made sure that is i didnt so. I used just the normal cable | |
03-09-2006, 15:48 | #9 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | Hello Simzmobiles, please post your log file, so we can see it and tell You what is the problem! Please hide your serial number in log! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-27-2006, 18:35 | #10 (permalink) |
Freak Poster Join Date: Jul 2004 Age: 54
Member: 73211 Status: Offline Thanks Meter: 5 | i have the same problem with v547 it comes on but goes off when booting and only shows light on the keypad .I have repaired pds and make full flash but its still the same.pls can anyone help with solution. Many thanx in advance |
help v3i r47a after unlock by pepare phone now in bootmode only | freakyass | Smart-Clip | 16 | 07-04-2007 03:40 |
L6....Stuck n Bootmode :confused: | cliffrock4u005 | Ultima Box Light | 14 | 03-28-2007 05:19 |
Motorola V3 pink in bootmode loader | bcnboy | Smart-Clip | 2 | 03-10-2006 19:11 |
E398 in bootmode show BATTERY LOW | Bezio | Motorola P2k | 0 | 12-27-2005 19:27 |
E398 Always in BootMode (flashMode) | Amir-SkillZ | Motorola P2k | 9 | 11-09-2005 13:23 |
