07-10-2008, 07:09 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ stefani, Please check these settings: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. You have reliable Internet connection 3. LPT port settings are set to EPP in BIOS 4. Your LPT cable works properly 5. You use a stable power supply with your clip (use power adapter) 6. Your IE version is not lower than v5.0 7. If you run update under WinXP, log in as Administrator or any other account with administrative rights 8. You should clear cache of your browser and restart the computer. To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SM-tool, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility Windows XP SP2: if you have problems running unsigned ActiveX, please open Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt" After that try to upadte your Smart-Clip, save log file and send it to support[at]smart-clip.com Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
my 6500c is dead, need help! | zaibitul | Nokia Base Band 5 ( BB-5 ) | 5 | 10-11-2010 15:44 |
My Smartclip Is Damage! Help Scard!" | enrikeparis | Smart-Clip | 3 | 06-23-2007 20:17 |
Is my Smartclip dead? | smartmod.de | Smart-Clip | 1 | 01-18-2007 08:30 |
smartclip dead please help!! | HUMBLE | Motorola ODM | 0 | 01-13-2007 22:55 |
my smartclip dead from scteam | cianyika | Smart-Clip | 4 | 09-07-2006 17:11 |
