Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 09-29-2007, 15:28   #1 (permalink)
Member: 138575
Need help to solve my clip detection problem
Halo hi,
My smart clip light goes off when I open smartmoto soft and press search, the red and green light both goes off and clip not detected. But there is no problem when I try to upgrade the clip.
I tried with an other smarclip on my system which is working (from a friend of mine) which he is using in his system w/o any problem, but Unfortunately in my system, in that also I have the same problem. So it understands that some setting problem in my system. Can somebody guide me to solve this?
Eagerly waiting for a quick reply.
jackle123
Old 10-01-2007, 09:13   #2 (permalink)
GSM_Support's Avatar
Member: 121052
Please make sure that:
  • Firewall on your computer (or your LAN) is configured properly or disabled
  • You have reliable Internet connection
  • LPT port settings are set to EPP in BIOS
  • Your LPT cable works properly
  • You have got a correct LPT port set in SmartMoto program, tab
  • Smart-Clip. The best way to use Auto mode.
  • You use a stable power supply with your clip (use 12V, 750mA power
  • adapter)
  • Your IE version is not lower than v5.0
  • If you run update under WinXP, log in as Administrator or any other account with administrative rights
To run a new SmartMoto under WinXP also to update a Smart-Clip please
launch the SmartMoto, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)".
After that restart you PC.
Also set LPT options in SmartMoto to compatibility.
Best Regards
GSMServer team
Old 10-03-2007, 10:19   #3 (permalink)
Member: 138575
THANK YOU VERY MUCH FOR YOUR REPLY. THE PROBLEM WAS WITH EPP SETTINGS IN BIOS MODE. I HAD IT KEPT IN AUTO, HENCE WAS FACING THE PROBLEM.
THANK YOU ONCE AGAIN FOR YOUR UNLIMITED SUPER SUPPORT.
jackle123
Smti Help to solve my Problem! about my New Smti UnLoCkit SMTi 1 03-27-2010 11:40
need help to solve GDFS problem Hafiz ArslanAli SETool2 9 11-12-2009 17:20
flashing 36 5.05.04.40 to solve my call dial problem phone hang up with nokia help idriss_gsm HWK 0 12-24-2008 17:25
Why no one replies to me? help to solve my problem clue_patel Nokia Multimedia 1 05-23-2007 20:47
Why noone replies to me? help to solve my problem clue_patel Nokia Multimedia 4 10-31-2006 16:03
Page generated in 0.31038 seconds with 11 queries
