03-09-2008, 13:40 | #1 (permalink) |
No Life Poster Join Date: Jun 1999 Location: Germany
Member: 233 Status: Offline Thanks Meter: 36 | Need V3RE repair flash urgent I try to unlock a V3re and make prepare "smart test point " a backup have doesn't work. Smart Test point have not work, I don't know, cable is checked over and over again. I need Flash to bring phone to live. Is German Vodafone model Many thanks |
03-11-2008, 09:07 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ jan, Flash files for this phone model can be found at boot-loader.com in PCF file section. *.pcf files can be used by SCout flasher. For more detailed info please visit www.scoutdongle.com Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-11-2008, 09:33 | #3 (permalink) | |
Freak Poster Join Date: Jan 2006 Location: SMcity pampanga & SMcity clark
Member: 218135 Status: Offline Thanks Meter: 7 | Quote:
can scout flasher revive dead argon phones? if not, is there any way to flash dead argon phones? i'm also searching ways to revive dead v3re during unlock process because i also have one right here if you can shed some ideas, maybe you can help me also! thanks! | |
03-11-2008, 10:04 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ amps_jas, To be able to flash the handset it has to be detected by the PC. In case if the phone can not be detected at all, most probably that it has some hardware malfunction. Please check the mainboard of the phone. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-11-2008, 10:12 | #5 (permalink) |
Freak Poster Join Date: Apr 2001 Location: Europe,Slovakia Age: 50
Member: 4354 Status: Offline Thanks Meter: 55 | Smart tespoint work.Phone not dead. Procedure 100% 1. conect dead phone V3re prepare smart testpoint 2 disconect cable conect smart testpoint cable and testpoint pin. 3 conect data cable and press start. solution tested 100% working. BR. MobilMan |
03-11-2008, 12:14 | #6 (permalink) | |
Major Poster Join Date: Dec 2007 Location: pilipinas kong mahal
Member: 654329 Status: Offline Thanks Meter: 7 | Quote:
Here's the log: (phone is dead now) strange...smartmoto reads phone as interface even if it's dead | |
03-11-2008, 13:42 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ bhruc, As can be seen from your screenshots, the phone get read as "S Blank...". In most cases it shows that the handset has some hardware malfunction, please check the PCB of the phone. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
03-11-2008, 22:26 | #8 (permalink) |
No Life Poster Join Date: Jun 2004 Location: Poland, Wroclaw Age: 50
Member: 67562 Status: Offline Sonork: none Thanks Meter: 89 | S blank mode means that phone was half prepared to unlock but somethink goes wrong. So it is need to use smart-TP to revive phone back. Connect phone via TP and click Prepare Smart Testpoint Do as popup windows shows. If software ask for writing temporary backup - click yes. |
Motorola v3re repair,flash,unlock problem! | JKKB | Smart-Clip | 2 | 11-24-2008 08:25 |
K700 Writing flash problem:0004!!! I need to repair it urgently | lisandrogalup | MT-BOX | 1 | 09-18-2006 21:00 |
need a repair flash for BF4 urgently | ab1009 | BF, BG, TH, BHx Series | 4 | 03-19-2004 15:20 |
Need V60 repair flash-file urgently! | VendorGSM | Motorola P2k | 5 | 10-14-2002 17:57 |
Need 3310 V 04.19F Repair Flash.. Urgent Please. | DrMobile | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 4 | 01-12-2002 09:05 |
