04-08-2006, 21:11 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Midlands, UK
Member: 57937 Status: Offline Thanks Meter: 34 | 'No Battery' When Test Point Unlocking Motorola?! I'm not sure if this has been asked or mention before. But the other week I was showed how to unlock an L7 via test point, but we forgot to insert the battery into the phone, but it still successfully unlocked. Today I tried an L6, and just had the phone's PCB connected to the Smart Clip, No battery attached or power supply to the PCB, and again it Unlock Successfully. It seem so much easier to do the unlock this way. Is this a safe method to use?! And is it common practice? and are others doing this? What other Motorola's can this method be used on? (Where no battery is required). But.... Maybe we were lucky with these two phones, and maybe this proceedure should not be done! Try it with Caution! |
04-09-2006, 01:25 | #8 (permalink) |
No Life Poster Join Date: Dec 2001
Member: 8102 Status: Offline Thanks Meter: 118 | No battery is required for the following phones only (as far as I know) Pebl U6, L6, E1, E790, V190, V557 With other models a batt is a must, as there is a good chance during unlocking/flashing not enough power is available through the Smart Clip box and phone can become dead ! Just my thoughts - Use at your own risk |
04-09-2006, 03:04 | #9 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | some times we got down battery from customers and we was affraiding,may be cell will dead due to down battery now we can do it without battery,its realy good news for us,thanx man. BR Kashif Khan |
04-09-2006, 04:52 | #10 (permalink) |
No Life Poster Join Date: Jul 2005 Age: 44
Member: 162029 Status: Offline Thanks Meter: 202 | This is confirm safe and effective even with e1 rokr tested by me using mss usb cable. connect testpoint to ground first before attaching cable and press search botton |
04-10-2006, 10:47 | #13 (permalink) |
Major Poster Join Date: Oct 2004
Member: 88848 Status: Offline Thanks Meter: 0 | yes this is right u dont need no battery on the phone jus connect testpoint press search and when unlocking let go of testpoint and leave usb cable connected and press unlock via testpoint |
> New TEST POINT FOR MOTOROLA V3xx , K3 , V6 V110 | MATRIX.REAL | Motorola P2k | 15 | 05-18-2009 16:37 |
Motorola Test Point Unlocking Video Guides | luckycool | Motorola P2k | 11 | 10-30-2006 15:15 |
test point diagrams motorola | dovecomms | Motorola P2k | 2 | 06-07-2006 07:40 |
All tests points for motorola | Gora1 | Motorola P2k | 2 | 05-11-2006 20:52 |
Test Point For Motorola | rajan nishchal | Motorola P2k | 30 | 04-27-2006 01:10 |
