03-09-2006, 22:29 | #1 (permalink) |
Junior Member Join Date: Oct 2004 Age: 47
Member: 86493 Status: Offline Thanks Meter: 0 | Pebl: keypad dead after unlock and flash without any error! I´ve just unlocked a new Motorola U6 Pebl from Orange via test-point, everything worked fine without any error or something. -> unlock o.k. was written. But when i inserted my Voda card afterwards i could not enter my pin-code anymore, because the keypad didn´t function anymore. The Sim card was recognised (-> phone is unlocked) but only the Power-on button is working and no other one! If done the Repair PDS (worked fine!) and i´ve flashed it again afterwards (worked fine too!) but the keypad woul´dn´t work I´ve tried the whole day now to find any solution without sucess - so your my last hope! Thanks, gimjen |
03-10-2006, 10:54 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Looks like a hardware problem. Possibly something was damaged during testpoint process. Best Regards GSMServer team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
08-06-2006, 17:22 | #5 (permalink) |
Freak Poster Join Date: Oct 2005 Location: www.unlockbylogs.com Age: 38
Member: 192997 Status: Offline Sonork: 100.1574661 Thanks Meter: 7 | while putting the phone together...make sure the side keys have been put back together proprly...that if u put those side keys other way rnd...it mite cause the keys not to respond. try if it works...or otherwise...u mite have damaged some part of the board in the TP process good luck |
08-06-2006, 18:51 | #7 (permalink) |
No Life Poster Join Date: Nov 2000 Location: Boro Age: 37
Member: 2461 Status: Offline Thanks Meter: 22 | Usual cause is damage to the keypad ic's ( 2 x small shiny square ic's below the testpoint) possibly levered against when cutting the shield Just replace them |
08-06-2006, 21:17 | #9 (permalink) | |
Member: 2461 Status: Offline Thanks Meter: 22 | Quote:
It is very easy to damage ( cutters , just resting against it as you cut the sheild ) | |
U880 Cant find any net after unlock and flash. [Solving] | braindead_sw | Z3X-Team Products | 2 | 09-11-2009 10:41 |
V3i Dead after unlock, and Critical error DE/CA now | desanclador | Motorola P2k | 7 | 11-30-2007 07:47 |
k1 dead after unlock and can't flash it | S.O.S.G.S.M | Smart-Clip | 3 | 06-03-2007 17:27 |
Z530 Serious error after unlock and flash! | mayer | MT-BOX | 7 | 12-21-2006 11:42 |
