12-03-2009, 08:18 | #1 (permalink) |
Junior Member Join Date: Mar 2004 Age: 64
Member: 59962 Status: Offline Thanks Meter: 2 | please help me E8 USB error 33 Connect phone to PC USB port, launch SCout multiflashe Flash the phone with Boot_Replacer.R6713_G_71.14.1ER_06AC.pcf but get error error 33 please help me Zeroing special code... USB error 33 You may also uncheck "Reset subsidy code" checkbox to force phone flashing |
12-03-2009, 08:28 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ hungb, Please uncheck option "Set subsidy code to "00000000"" in SCout flasher and run unlock procedure according to the manual, once again. Best Regards GSMServer team |
12-03-2009, 10:06 | #4 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ hungb, In order to unlock this phone model the set has to be flashed with the Boot_Replacer and Special MotoMAGX flash files, more detailed information can be found here. Do not turn on "Set subsidy code to "00000000"" option is SCout flasher, otherwise "USB error 33" will appear and flashing procedure won't be completed successfully. Best Regards GSMServer team |
12-04-2009, 08:30 | #5 (permalink) | |
Member: 59962 Status: Offline Thanks Meter: 2 | E8 flash error error 33 test ok Quote:
1 launch SCout multiflasher FLASH Boot_Replacer.pcf [on the phone enter into boot mode by * + # + power button] NO get error error 33 2 launch SCout multiflasher FLASH R6713_G_71.14.1CR_GSXELBAAPID074_ L 0021_fw.pcf 3 Launch SmartMoto Press and hold keys 4 and 6 on the phone and insert the battery. Phone starts loading and within 3-5 seconds the display should indicate the message “Motorola test mode”. Release keys 4 and 6. UNLOCK OK firmware R6713_G_71.14.1ER_B keys 4 and 6 on the phone not working Motorola test mode flash firmware R6713_G_71_14_1AR or R6713_G_71_14_1CR /keys 4 and 6 on the phone working Motorola test mode test ok | |
The Following User Says Thank You to hungb For This Useful Post: |
8600b please help me with usb cable | VUONGKDUNG | MT-BOX | 1 | 08-24-2007 13:00 |
Can someone please help me with the error invalid pointer | daniello | Nokia Base Band 5 ( BB-5 ) | 2 | 01-11-2007 23:46 |
PLease help me correct my error | nishantha | Nokia Base Band 5 ( BB-5 ) | 2 | 12-15-2006 12:25 |
Please Help me for 6230 Error 44449100 again again... | selammi | Griffin | 6 | 09-06-2005 22:48 |
please help me the sagmaster error | wengming | SagMaster Team OLD Products | 1 | 04-26-2005 09:31 |
