Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 07-01-2008, 04:59   #1 (permalink)
Member: 595342
please help me I can't install smart clip!!!!
Last week i received the smart clip, smart-card and smart adaptor from unlockcellular. I want to use in my laptop but it can recognize the smart adaptor and, in consequence, the smart clip. I have 20 phones waiting for service but i can't do this job because of this problem.
Could you tell me what I am doing wrong? I have disabled the os parallel port polling and restarted the laptop. I don't know what to do.
I checked the smart adaptor in another pc but the same problem.
Please I need your help!!!
I installed the drivers but still the same.
Old 07-01-2008, 05:27   #2 (permalink)
Afzaal's Avatar
Member: 128918
take time to read it.
http://www.smart-clip.com/index_adaptor.php
Old 07-01-2008, 05:34   #3 (permalink)
Member: 597688
remove all smart clip software & again install after installtion, attech s-card & smart clip after this press start button/programs/s card updater (smart clip red & green lights allways on if these light off then change suplly), if here show smart clip error, then open www.smart-clip.com site & update smart clip Latest versionsclick) Smart-Clip v4.07 (04.03.08)
then open Update mirror 2 click, there open new page now right click "install activex control" install it, after install this make a new windows now update your smart cilp box 100% sure work your smart clip box (malkeetranjeet@yahoo.com)
Old 07-01-2008, 18:37   #4 (permalink)
Member: 595342
How can i know if the smart clip works fine without using smart adaptor?
the smart adaptor only shows red light when I connect to laptop. is it right?
Old 07-01-2008, 18:45   #5 (permalink)
Member: 741807
install latest smart moto software, connect smart clip and s-card....serial nos. will be detected.
Old 07-02-2008, 07:58   #6 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
@ zeppelin79,
First install drivers for the Smart Adaptor and S-Card:
Smart Adaptor installation
  1. Please download and install SmartMoto v3.00 or later version.
  2. Connect Smart Adaptor to PC USB port.
  3. The system detects a new device.
  4. Please locate the driver for Smart Adapter
  5. The Smart Adaptor is ready for update.
Drivers for the S-Card and detailed description of the installation procedure can be found here. After all drivers installed, restart the PC.
Update Smart Adaptor:
  1. Connect Smart Adaptor to PC USB port.
  2. Log to Update Zone at www.smart-clip.com.
  3. Log to the Advanced tab.
  4. Select USB port in "Communication Mode".
  5. Lot to Smart Adaptor tab.
  6. Press "Update" button.
  7. The updater detects the Adaptor serial number.
  8. The new firmware will be loaded to the device.
  9. The Smart Adaptor is ready to be used for any Smart-Clip function
Update the Smart-Clip
  1. Connect Smart Adaptor and S-Card to PC USB ports.
  2. Connect Smart-Clip to the Smart Adaptor.
  3. Power Smart-Clip ON (warning: don’t use battery!);
  4. Log to Update Zone at www.smart-clip.com.
  5. Log to the Advanced tab.
  6. Select USB port in "Communication Mode".
  7. Log to Smart-Clip tab.
  8. Press "Update" button;
  9. An ActiveX client should detect Smart-Clip serial, firmware version and S-Card serial, update process begins;
  10. New firmware is loaded.
Update the S-Card:
  1. Connect S-Card dongle to PC USB port;
  2. Connect Smart-Clip to PC using Smart Adaptor or LPT cable;
  4. Go to our Update Zone;
  5. Update Zone uses ActiveX control, answer "Yes" to install and run it;
  6. Log to the S-Card tab;
  7. Press "Update" button;
  8. An ActiveX client should detect Smart-Clip serial, firmware version and S-Card serial, update process begins;
  9. New firmware is loaded.
Download and install latest version of the SmartMoto. Now you can work with any supported phone model. Detailed description for the unlock/flash procedures can be found at www.smart-clip.com in the SmartMoto section.
P.S. In case if during update procedure some error appear, save log file and send it to support[at]smart-clip.com
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 07-02-2008, 09:14   #7 (permalink)
Member: 597688
smart adaptor light show but smart clip box light red & green very imortent
these light on that's smart clip voltage ok
if voltage not ok then these lights not on
you are not use smart adaptor USE only DC POWER SUPLLY OR BATTERY BOOSTER (ELIMINTOR 1.5v to 12v)
smart clip RED & GREEN light allways on only give power supply (without computer attech) if light not work that's your smart clip box faulty
Old 07-02-2008, 22:00   #8 (permalink)
Member: 595342
first of all:
Smart-Clip update software 3.00
Warning: make sure you use power adapter!
USB Device not found
That's happen when I connect the smart adaptor. The Smart adaptor only shows red light. The smart clip when i connect to power adapter shows red and green light. I think this is correct for the box, but happen with the smart adaptor. I have installed the drivers. Just when i connect to the usb port says "it would faster better in a usb port 2.0" the s-card can be read but the other devices not.
Should i buy a new smart adaptor? (i have just 6 days with it , it's new).
I have done all the procedure step by step but the same "USB device not found" and sorry for the inconvenience but i really need to solve this fast because i have many phones to work with.
And thanks for your help specially Malkeet
Old 07-03-2008, 09:00   #9 (permalink)
Member: 229997
@ zeppelin79,
Check this link, please.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Old 07-03-2008, 19:23   #10 (permalink)
Member: 595342
Thanks for your patience and time. I will try reinstalling drivers again and again. I buyed the lpt cable to do the pending work in another pc and hoping the smart clip works fine. I work with a laptop so that's why i buyed the smart adaptor. I will post results.
Old 07-03-2008, 21:05   #11 (permalink)
Member: 595342
Finally i have installed the smart adaptor smart clip and s-card. Uff. Just reinstalling drivers until it works. Just need to install U2l adapter boot loader (driver) to acces to boot-loader.com
Where can i find this driver?
Old 07-03-2008, 22:32   #12 (permalink)
Member: 595342
Solved.I just needed to reinstall the clipusb driver again. Now i get the next error when trying to update smart adaptor :
Smart Adaptor serial: 16******x
Boot version: 1.00
Firmware version: 1.00
Smart adaptor warranty period:
03-Jul-2008 to 30-Dec-2008 (180 more days)
Getting update package ...
internal server error
Update error
I have updated the smart clip and s-card but the smart adaptor doesn't.
What can i do?
Thanks for all of you who helped me.
Old 07-04-2008, 02:44   #13 (permalink)
Member: 595342
Finally, i've got updated the smart adaptor. Just try and try. Was a server problem.
Thanks anyway.
Old 07-05-2008, 10:31   #14 (permalink)
Member: 597688
first of all:
You are USE only parellel port not use USB Port parellel port is very easy to install
Old 07-07-2008, 03:04   #15 (permalink)
Orange_Dominica's Avatar
Member: 88701
Zeppelin 79 ...Good work on the troubleshooting , and thanks for posting valuable info.
Malkeet, his computer HAS NO Paralell Port....common on many laptops of today, so he must use SmartAdaptor.
;smokin
Please Help Me To Update My Smart Clip,Step by step!!!Thx! dmaetrey Smart-Clip 10 12-24-2010 15:11
Can Anybody Help Me To Replace My Smart Clip? leviswang Smart-Clip 11 01-18-2006 23:11
TST Team Please hel me I can't install TST waresee TST Dongle 9 10-09-2005 10:09
Plz help me, I can't install .sis file on my 6630 simlock phanquitra Nokia Base Band 5 ( BB-5 ) 12 09-20-2005 09:24
help me unlock c975 with smart clip samirsana P2k Series 13 01-05-2005 11:26
Page generated in 0.49004 seconds with 11 queries
