04-19-2008, 08:29 | #1 (permalink) |
No Life Poster Join Date: Feb 2007 Location: india Age: 47
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | ploz help me for E1070 unlock Last edited by GSM_Support; 04-19-2008 at 11:01. Reason: Contained Serial number |
04-19-2008, 11:03 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | To all users. Please remember to keep Smart-Clip serial number in secret at all times. The serial can be only posted to Smart-Clip support team via e-mail or Private message. Please be aware that all serials that are posted at any public forum will be immediately blocked for good. There will be no return for the blocked Clip. It will never become functional again. Best Regards GSMServer team |
04-19-2008, 13:41 | #3 (permalink) |
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | SmartMoto 3.14 S-Card: ******** Smart-Clip dongle, v 2.08, assigned Smart-Clip: ******** Europe, initializing... OK Clip serial: ********, version: 4.07, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.81 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 356853002******* WARNING! Your phone may not power on after downgrading firmware version. This phone can be unlocked only via patching. IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 356853002979062 (7).mbk" Now you can perform Repair PDS or Unlock operations. To get phone to work, you should write flash into the phone error A9 Phone unlock failed Searching for phone... clip communication failed Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Phone is not in flash mode. Please enter flash mode before patching the phone. This can be done by pressing 'Enter flash mode' button on 'Flash' tab (for old boots only!). For newer boots, use 'Prepare phone' operation or TestPoint method. Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.81 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 356853002979062 WARNING! Your phone may not power on after downgrading firmware version. This phone can be unlocked only via patching. IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 356853002979062 (8).mbk" Now you can perform Repair PDS or Unlock operations. To get phone to work, you should write flash into the phone |
04-20-2008, 12:55 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | just do the flash from any file from the server and then just make the IMEI repair and ur phone will be alive in a second if u already flashed it and phone is dead then just change the IMEI make it again the same as old one and phone will be alive. NAEEM FAROOQUI. |
04-20-2008, 17:39 | #5 (permalink) |
Member: 446363 Status: Offline Sonork: 1577571:rajtelecom Thanks Meter: 216 | tnx for help my friend my phone is unlocked SmartMoto 3.14 Looking for S-Card... not found (card readers searched: 0 of 2) Looking for S-Card... not found (card readers searched: 0 of 2) S-Card: ********* Smart-Clip dongle, v 2.08, assigned Smart-Clip: ********* Europe, initializing... OK Clip serial: *********, version: 4.07, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Searching for phone... clip communication failed Clip serial: *********, version: 4.07, initializing... OK Searching for phone... found Motorola Phone (E1070), getting test interface... OK Model E1070 Firmware R252211LD_U_85.97.F11P Switching to flash mode... clip communication failed Switching to flash mode... clip communication failed Switching to flash mode... clip communication failed Clip serial: *********, version: 4.07, initializing... OK Searching for phone... no phone found Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.84 Boot prepare... failed Searching for phone... no phone found Clip serial: *********, version: 4.07, initializing... OK Searching for phone... found S Flash Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 6.84 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Rainbow POG Switching to flash mode... OK Reading phone boot version... 3.10 Reading flash id... Intel - 28F256L18B (x2) Phone group: E770,E1000,E1070,V3x,V975,V1050 Hardware IMEI: 356853002979062 WARNING! Your phone may not power on after downgrading firmware version. This phone can be unlocked only via patching. IMEI OTP status: locked Security area saved to "PDS for S Blank Rainbow POG 356853002979062 (1).mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_D7161C0C8C4C2262.bk_ Restore OK Now you can perform Repair PDS or Unlock operations. Sending firmware Writing flash section 2 of 2... 100% (21 Kb/sec) Applying unlock patch, please wait (up to 2 minutes!)... OK Phone is unlocked |
Ustpro Teem Help Me For U300 Unlock | rajtelecom | UST Pro II | 0 | 12-30-2007 00:49 |
help me for 8330 unlock | dalime1 | LG | 1 | 05-31-2005 19:28 |
help me for 8310 unlocking cables | UHK | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 08-03-2002 13:35 |
help me for m100 unlocking | gsnbhagawan | VLSI, Conexant, Skyworks and Old Models | 3 | 01-05-2002 06:46 |
Help me for c35 unlocker v11 | iowtheme | x1x to x45/x50 | 1 | 04-21-2001 23:09 |
