Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 01-31-2006, 21:17   #1 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161 GSM GURU
Plz Help L6 Unlocking
Please I Have (5) Five Motorola L6 Phones With Lock On Them ,but Plz I Want To Know If There Are No Erros In Unlocking L6 Via Tespoint With This New Smart Clip Update ,because I Have Not Tryed To Unlock L6 Via Testpoint With This New Version Before,i Only Tryed With V360 (3 )three Pieces And I Unlocked Them Sussesfully,so I Want To Know Can I Unlock This L6 Phones Also Sussefully, Via Test Point Withouit Causing Any Damage To This Phones.
Thanks In Advance
Old 02-01-2006, 21:23   #2 (permalink)
ARAB GSM's Avatar
Member: 180675
thanks to all i have unlocked all my LOCKED L6 phones sussesfully,but i always see invalid battery on one of the phones lcd any time i power on the phone, it can make calls and recieve calls but always invalid battery on lcd,please i need help to solve this invalid batery problem
thanks to all in advance
Old 02-02-2006, 10:42   #3 (permalink)
Member: 220794
plz freind what solution had you use for unlocking this model???
Old 02-02-2006, 10:52   #4 (permalink)
GSM_Support's Avatar
Member: 121052
Lightbulb
Hi.
the only correct procedure is described at our support site:
Unlock procedure for L6 Motorola phone with testpointUsing "Unlock via Testpoint" function of SmartMoto method
  1. Perform corresponding testpoint procedure
    http://www.smart-clip.com/testpoints/L6.php
  2. Use "Unlock via Testpoint" function of SmartMoto from "Unlock" tab
Please note:
We strictly recommend to make a backup of flash from any L6 handset before performing any procedure. If the process fails to complete you will be able to restore your handset to its original state.
Old 02-02-2006, 11:21   #5 (permalink)
irishclips's Avatar
Member: 84155
It seems that most "invalid battery" problems are caused by removal of the metal cover. This is where some of the board cicuitry is lifted while taking off the cover
Old 02-02-2006, 13:22   #6 (permalink)
Member: 220794
can i use smartmoto without smartclip?
Old 02-04-2006, 18:26   #7 (permalink)
ARAB GSM's Avatar
Member: 180675
I head there i a crack version of the smart motto, but man the best solution for u is to buy smart-clip.and unlock the high versions via test point tested 100%
thanks to all good luck
plz plz help in unlocking k800i med26 Sony Ericsson 1 02-11-2010 20:37
plz help l6 code unlock kakaomar Smart-Clip 1 12-23-2009 07:38
k610 can not unlock plz help after unlock no power negm-- SETool2 1 11-14-2009 05:38
Plz help L6 charging brain00000 Motorola Hardware Repair Section 1 04-14-2008 01:52
plz help me unlock my nec e606 need big help bigman_666 Phone Unlocking Codes & Maps 11 09-17-2004 16:40
Page generated in 0.29937 seconds with 11 queries
