Problem Connecting with Smartmoto Hi When I try to connet with Smartmoto my clip says Clip Serial 8229xxxx, version: 2.15, intializing.....error 98 Whats this mean, What do I do please. Regards Charly |
Which windows are you using?Check also your lpt conf. |
Regards Charlie |
SC Team, NEED urgent solution for "............ ERROR 98" with SmarMoto and SC http://forum.gsmhosting.com/vbb/showthread.php?t=220428 With SmartMoto v1.05 say "Smart-Clip not found" |
http://www.smart-clip.com/dl_user.php?id=smartmoto |
Searching for Clip Clip not Found It works fine on update site but smartmoto wont find the SmartClip at all :( . Regards Charlie PS I have sorted it now it was a registry issue with smartmoto :D :D :D |
Did you open: SmartMoto>>Smart-Clip & tick on "Disable parallel port polling (requires reboot)" ?? BR Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Hi SC Yes of Course I did disable polling as your web page suggested and restart the PC but this was not the problem as I can link to smartmoto and smartclip with both polling on and off as I have always been able to do before and after upgrade, but of course I take your advice and have turned polling off now. Regards Charlie |
Me too, I have Smart-Clip, UPDATE GOOD, UNLOCK WORKS GOOD, but now I can't connect to SmartMoto ??? Before with 2.14 and SmartMoto 1.04 was working good! Now I tried connecting the clip to 1.04 and 1.05 SmartMoto, but always clip not found!!! On the SupportZone update/checking version is working perfectly!!! WHAT HAPPEN TO SMART MOTO ????????????????????????? thanks |
Yes, i am sure you did, but you must install the latest SmartMoto first.. BR Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Hi Lucky7Napoleon what I did was uninstall all smartmoto versions with the control panel add/remove then delete all registry entries and keys for smartmoto then restart and reinstall the latest 1.05 smartmoto. Hope this helps Regards Charlie |
thank SC for support, faster than light! bye bye :D |
Did you sort it out, How did you get on mate. Regards Charlie |
my smart clip wont connect to smart moto and wont unlock anything anymore my smart clip wont connect to smart moto and wont unlock anything anymore after update to 2.14 it **** the clip and wont unlock anything :mad: after update to 2.15 stil nothing smart clip update went wel everything check out but nothing works. :confused: smart moto connect to the box reads out serial nr and log but gives comunication error. please smart clip team help me to get my smart clip working again because else i will have to buy a new box and then it woudend be a smart move for me to buy a new smart clip. :( many thankx in advance. |
Did you install a latest SmartMoto vesion 1.05? BR Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
