Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 11-30-2005, 20:44   #1 (permalink)
*MaTeOoSh*'s Avatar
Member: 2755
Problem with downgrade new V980M
Hi !
I've the problem with downgrading V980 (R26) to R24 version (I need 2F langpack inside, and the good working one is available only for R24). Already done about 30 pieces of V980, but this one doesn't want to flash. It's a new one, because it's detected as E1000/V975 family, and the RSA remove procedure is like by V975. Here's the log
Searching for phone... found Motorola Phone (V980M), getting test interface... OK
Model V980M
Firmware R26_U_83.38.38.04.01P
Reading info OK
Switching to flash mode... OK [S Flash Rainbow POG]
Reading phone boot version... 6.31
Flash completed!
Searching for phone... found S Blank Rainbow POG
Reading phone boot version... 3.10
Reading bus width... OK
Reading flash id... Intel-28F256L18B (x2)
Phone group: E1000,V975,V1050
Hardware IMEI: 3556xxxxxxxxxxx
Security area saved to "S Blank Rainbow POG 3556xxxxxxxx.pds"
Phone initialization... OK
"Remove RSA" performed successfully, you may service and unlock the phone as usual
Turning phone off... OK
Model V980M
Reading info OK
Reading phone boot version... 5.F1
Hardware IMEI: 355603xxxxxxx
Security area saved to "Motorola V980M 35xxxxxxxxxxxx.pds"
Error: file flash data (32 Mb) does not suite phone memory
Hmm, any ideas ? Maybe I should put her an V975 flash, but unfortunately now (21:45 GMT+1) boot-loader.com doesn't work at all ...
Old 11-30-2005, 21:47   #2 (permalink)
moldovan's Avatar
Member: 23684
Sonork: 1582723
In Smart Clip section , is about 12 thread's about problemm's V980M
Firmware R26_U_83.38.38.04.01P !
May You can't read English ?
Why You post duble thread ?
You need to flash 64 Mb in to this phone , use it from V975.
WBR!
Old 11-30-2005, 21:58   #3 (permalink)
ceedee's Avatar
Member: 5268
@ Mateoosh
PM me or GG (2040781) I'll give you all things and information tested with this version...
Old 12-01-2005, 14:10   #4 (permalink)
*MaTeOoSh*'s Avatar
Member: 2755
WBR!
ye ye ye - too lazy to make a search, sorry.
Old 12-17-2005, 10:51   #5 (permalink)
Member: 196054
hi mate
first of all it will be very cool to share all solution ar idea about flashing new motorola
second why downgrade this v980. if it's for unlocking u can use tne v975-v1050 test point described in smart clip web site and do unlock by test point and all will be ok test for me today
best regards
Old 12-19-2005, 21:22   #6 (permalink)
Member: 151973
Unhappy
Originally Posted by casper007
hi mate
best regards
Sorry, I just killed a V980M today doing exactly how you say here..., not because of you, I killed befor I see your post, but I can say that the phone is dead, it's not power on even in BootLoader (with *&# pressed).
can enybody help me with this?
ps.SORRY FOR MY ENGLISH
Old 12-20-2005, 05:45   #7 (permalink)
Amir-SkillZ's Avatar
Member: 91045
Sonork: 100.1577222
@sorin4tel
Just do the TP as on Smartclip site for ur Mobile and mobile will get connected....Tested many times TP is Specially worked for Dead mobile like u have...After that Repair PDS and then Full flash And bezure to use it from v975 64mb flash or u will get error again and no need for Check "overwite boot area" DO as i Say then Post results
Great Problem With Downgrading Nec 338! Urgent Need Help! KUBAT1 NEC 1 03-17-2006 09:41
Strange problem with downgrading Siemens c45 Sher x1x to x45/x50 0 03-15-2002 23:00
vBulletin Optimisation provided by vB Optimise v2.5.2 (Lite) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. ()
Page generated in 0.33323 seconds with 12 queries
