12-01-2009, 02:01 | #1 (permalink) | |
Freak Poster Join Date: Nov 2004 Location: Argentina Age: 69
Member: 91019 Status: Offline Thanks Meter: 62 | Problem with em35 unlock I`m having a problem to flash 1 "em35" to unlock, i open the scout flasher load the file boot replacer and i get this error , battery is fully charged, and the phone hardware is ok Quote:
Thank you very much!!! | |
12-01-2009, 09:03 | #4 (permalink) |
Freak Poster Join Date: Feb 2007 Location: Kumasi,Ghana
Member: 448929 Status: Offline Sonork: 100.1573624 Thanks Meter: 20 | Maybe you did not pick the correct boot file. i had the same problem flashing ZN5 128mb. i pick boot file for ZN5 and i had errors but later realised i was making a mistake. Pls chk boot file well and make sure phone is detected by scout b4 u do anything |
12-01-2009, 09:05 | #5 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Quote:
12-01-2009, 19:19 | #7 (permalink) | ||
Member: 91019 Status: Offline Thanks Meter: 62 | well i still having problems i flash the phone with this firmware to make it power up Code: R6743_G_74.31.02R_PRDonyx_GSXONYX00APHKGEN07C_PDS00E_LP0053B_GSXONYXAPHKGEN_S053_E017_R049_G001_1FF_Generic.pcf Thank you for your help here is the log Quote:
now i`ll try with another firmware from special firmware | ||
12-01-2009, 20:38 | #8 (permalink) | |
Member: 91019 Status: Offline Thanks Meter: 62 | i did try with 4 firmwares i tried with the 4 fw form special files and the result is the same phone doesn`t power up... i make it power up with the firmware Quote:
what can i do ? thank you very much | |
12-02-2009, 07:32 | #9 (permalink) |
Member: 239548 Status: Offline Thanks Meter: 2,781 | Flash with special_Motomagx folder and perform unlocking procedure correctly after that: http://www.smart-clip.com/support.php#MotoMAGX |
12-02-2009, 09:59 | #10 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ trivialnoise, Please download R6743_G_74.31.00R_onyx_boot_0905_v2.pcf once again flash the phone with it using SCout software, after that flash the set with the R6743_G_74.31.02R_PRDonyx_GSXONYX00APHKGEN07C_LP00 53B_Generic_fw.pcf and run unlock procedure according to the manual. Best Regards GSMServer team |
12-02-2009, 16:10 | #11 (permalink) | ||
Member: 91019 Status: Offline Thanks Meter: 62 | no power on after operation i erased from my disc the boot replacer and download again this file and the special firmware, i flashed the boot replacer first and then the special firmware Quote:
I make it power up again with fw Quote:
Thank You Very Much!!! | ||
12-02-2009, 16:26 | #12 (permalink) | ||
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ trivialnoise, Quote:
Best Regards GSMServer team Last edited by GSM_Support; 12-02-2009 at 16:32. | ||
12-02-2009, 18:13 | #13 (permalink) |
Member: 91019 Status: Offline Thanks Meter: 62 | here you are log of the entire flash process first boot repalcer Code: SCout 1.18. Flashing phone "???????????????? - R6743_G_74.31.02ROX_74.31.02R" with firmware "F:\Flash\flashes motorola\R6743_G_74.31.00R_onyx_boot_0905_v2.pcf"... Loading file "F:\Flash\flashes motorola\R6743_G_74.31.00R_onyx_boot_0905_v2.pcf"... OK Zeroing special code... OK Switching to flash mode... Preparing firmware image... Loading RAM downloader for bootloader... Erasing flash memory... Erase completed! Flashing code group 30... Code group 30 flashed Flashing code group 32... Code group 32 flashed Verifying checksums... Code group 30 checksums match Code group 32 checksums match Phone is being rebooted... Flash completed successfully SCout 1.18. Flashing phone "???????????????? - R6743_G_74.31.02ROX_74.31.02R" with firmware "F:\Flash\flashes motorola\R6743_G_74.31.02R_PRDonyx_GSXONYX00APHKGEN07C_LP0053B_Generic_fw.pcf"... Loading file "F:\Flash\flashes motorola\R6743_G_74.31.02R_PRDonyx_GSXONYX00APHKGEN07C_LP0053B_Generic_fw.pcf"... OK Zeroing special code... OK Switching to flash mode... Preparing firmware image... Loading RAM downloader for bootloader... Erasing flash memory... Erase completed! Flashing code group 31... Code group 31 flashed Flashing code group 34... Code group 34 flashed Flashing code group 35... Code group 35 flashed Flashing code group 36... Code group 36 flashed Flashing code group 37... Code group 37 flashed Flashing code group 41... Code group 41 flashed Flashing code group 42... Code group 42 flashed Flashing code group 43... Code group 43 flashed Flashing code group 44... Code group 44 flashed Flashing code group 45... Code group 45 flashed Flashing code group 46... Code group 46 flashed Flashing code group 48... Code group 48 flashed Flashing code group 50... Code group 50 flashed Flashing code group 52... Code group 52 flashed Flashing code group 60... Code group 60 flashed Flashing code group 61... Code group 61 flashed Flashing code group 62... Code group 62 flashed Verifying checksums... Code group 31 checksums match Code group 34 checksums match Code group 35 checksums match Code group 36 checksums match Code group 37 checksums match Code group 41 checksums match Code group 42 checksums match Code group 43 checksums match Code group 44 checksums match Code group 45 checksums match Code group 46 checksums match Code group 48 checksums match Code group 50 checksums match Code group 52 checksums match Code group 60 checksums match Code group 61 checksums match Code group 62 checksums match Phone is being rebooted... Flash completed successfully i disconnect phone and i put in boot mode and there is no error on boot now but when i try to power up show the motorola logo and then boot mode with the folowing error err:a5, 70, 00, 00, 24 thank you very much whatever you need please tell me |
12-09-2009, 15:52 | #15 (permalink) |
Freak Poster Join Date: Apr 2004 Location: Made In Brazil
Member: 62561 Status: Offline Thanks Meter: 706 | Same to me... follow same steps above and all looks fine, but after flash shows "Err: A4, 8B, 72, 00, 24" and doesn´t power on. Phone is alive again after flashing original firmware "R6743_G_74.12.01R_PRDonyx_GSXONYX00CLABRLA07C_PDS 00E_LP0003C_GSXONYXCLABRLA_S027_E010_R023_G004_WIG 127775_1FF". Same solution? b.r. Cryspim |
j132 unlock problem with d unlocker | oumar | Cruiser Suite | 1 | 05-23-2009 12:18 |
Problem with 6300 unlocking with new methode | Bloedman | UID - Box | 10 | 10-24-2007 08:24 |
problem with a65 unlock with test point. help me | Krafk | E-Gold Based Phones | 0 | 01-10-2005 13:32 |
PROBLEM WITH Z5 unlocking | email_me_links | Sony | 0 | 11-03-2001 18:40 |
Problem with S35 Unlock | Marcin | x1x to x45/x50 | 3 | 01-09-2001 01:29 |
