Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 10-05-2007, 03:19   #1 (permalink)
Member: 276875
Problem prepaire w510 !!! PH SIG ERR:39:02:
Hi :
when im prepare the phone all process are ok, but the phone restart in flash mode and PH SIG ERR:39:02:
this ok ? or have and error ? im usin the last update.
Old 10-05-2007, 07:30   #2 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 614
@ Juanitoesn,
To be able to see what goes wrong we need to see log file, please upload it here.
P.S. Don't forget to hide your serial number.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 10-05-2007, 13:36   #3 (permalink)
Member: 276875
this the log :
SmartMoto 2.38
S-Card: xxxxx Smart-Clip dongle, v 1.49, assigned Smart-Clip: xxxxxx Europe, initializing... OK
Clip serial: xxxxxxxx, version: 3.25, initializing... OK
Searching for phone... no phone found
Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... C.50
Sending boot... OK
Erasing flash memory OK
Sending firmware OK
Searching for phone... found S Blank Neptune LTE2
Reading phone boot version... 4.00
After this, im emsambled the phone, and put the battary, the phone power on in flash mode and show "PH SIG ERR:39:02:" error.
This solution really work ? i chek the cable 100% correct whit the smart clip tp scheme.
Old 10-05-2007, 13:49   #4 (permalink)
Member: 229997
Thanks Meter: 614
@ Juanitoesn,
As can be seen from your log file, most probably that Smart TestPoint procedure wasn't made properly.
Also one of possible reasons for such error could be hardware malfunction of the mainboard of the phone.
Please double check the manual and perform procedure exactly as it written there.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Old 10-05-2007, 14:57   #5 (permalink)
Blitzkrieg_Hop's Avatar
Member: 199739
Thanks Meter: 15
Change resistors in smart-testpoint...
Old 10-05-2007, 17:16   #6 (permalink)
Member: 276875
resistor ? o transistors ? transistors have ben changed, i sink is a problem in prepaire procedure, please help
Old 10-05-2007, 18:08   #7 (permalink)
Member: 67240
Thanks Meter: 40
yuor cable does not work...
Old 11-21-2007, 05:44   #8 (permalink)
Member: 75539
W490
Same problem here. I was trying to unlock W490 When I assembled it ,its stuck in flash mode. PH SIG ERR 39:02. What's the solution? Is cable bad?
Old 11-21-2007, 08:46   #9 (permalink)
Member: 229997
Thanks Meter: 614
@ MESCAPE,
In case if boot version get detected as 4.00, most probably that the PCB has hardware malfunction.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Old 11-28-2007, 20:56   #10 (permalink)
Member: 75539
W490
Hardware malfunction? How do I fix that? are you saying PCB is damaged?
Old 11-29-2007, 08:54   #11 (permalink)
Member: 229997
Thanks Meter: 614
@ MESCAPE,
Try to run unlock procedure via Prepare Smart TesPoint procedure ad Smart TestPoint procedure once again. If some error appears, please post log file here, don't forget to hide your serial number.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
Old 11-29-2007, 16:36   #12 (permalink)
Member: 104066
Thanks Meter: 62
When u make prepare smart TP procedure if u get error PH SIG ERR 39:02 when phone restart or when u dissemble phone, don't worry i have this problem too when i try to unlock W490, dissemble phone and continue procedure
now phone is 100% unlocked
Old 11-29-2007, 18:45   #13 (permalink)
nyakam's Avatar
Member: 260658
Thanks Meter: 156
please post me shema how to change transistor on smart testpoint cable if some one have itThak's in advance
w490 after unlock PH SIG ERR:39:02: .:Morpheus:. Smart-Clip 47 05-19-2011 07:30
w490 after unlock PH SIG ERR:39:02: Problem solve jakoy Smart-Clip 2 01-17-2009 05:27
W490 Sig Err:39:02: bebiloku Smart-Clip 10 05-05-2008 23:44
Ph Sig Err:39:02 reactos Motorola P2k 1 09-08-2007 12:25
Motorola V3r PH SIG ERR: (0A:52) bbmad Smart-Clip 1 02-11-2007 16:21
Page generated in 0.45011 seconds with 8 queries
