Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 01-23-2007, 13:24   #1 (permalink)
Member: 29155
Thanks Meter: 15
Problem with smartmoto (could not get USB descriptor)
I use SmartMoto 216
I try about 10 different phones (V600 V3 L7 L2 ... ) and get the same error when I press search button I get "could not get USB descriptor or no phone found" (phone connected to smart-clip and in flash mode). But when I connect it to PC usb-port - all ok. Smart clip found it and can flash. I changed 2 diff cables.
I think it happend after upgrade to 112 fw.
When I connect switched on phone clip detects it and can operate it test mode
For example here is log of new 100% working L2
SmartMoto 2.16
S-Card: xxxxx86xx Smart-Clip dongle, v 1.12, assigned Smart-Clip: xxxx65xxx Europe, initializing... OK
Clip serial: xxxx65xxx, version: 3.12, initializing... OK
Searching for phone... could not get USB descriptor
Searching for phone... no phone found
Searching for phone... found Motorola Phone (L2), getting test interface... OK
Model L2
Firmware R3511_G_0A.53.15R
Reading info OK
SC team please help me
Old 01-23-2007, 14:50   #2 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Thanks Meter: 616
@ Jiminay2000,
Please tell us what power adapter you are using.
Smart-Clip suppose to work properly with Power adapter 9V 500mA.
Also please check cables, if you have tried to change USB cables and power adapter is 9V 500mA, please write a letter to support[at]smart-clip.com with log file and your serial numbers (Smart-Clip, S-Card) and description of your problem.
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
www.smar*********er.com
Old 01-23-2007, 18:32   #3 (permalink)
Member: 29155
Thanks Meter: 15
my power suply and cables is ok
I'm not newbie with smartclip I used it about 1 year without problems
Old 01-04-2008, 15:38   #4 (permalink)
rajumobile's Avatar
Member: 54993
Thanks Meter: 46
I also face the same problem
Could not get USB descriptor.
Tested with two phones l6 and v3x.
Change USB cable, power supply is of 9V and 1000 ma.
please help.
Old 01-04-2008, 16:04   #5 (permalink)
Member: 229997
Thanks Meter: 616
@ rajumobile,
Please save log file and send it with your serial numbers and the description of the problem to support[at]smart-clip.com
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
could not get USB descriptor scutarus Smart-Clip 15 06-02-2009 07:44
Boot_loader Login Problem with Smartmoto on USB Top_Banana Smart-Clip 10 02-28-2009 21:40
Could not get usb discriptor i_am_rocky Smart-Clip 17 01-10-2008 13:48
could not get USB descriptor L6i wyroskl Smart-Clip 5 11-10-2006 19:52
5110 -could not get mobile sw baraka42 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-26-2003 19:06
Page generated in 0.28356 seconds with 8 queries
