11-15-2007, 11:37 | #1 (permalink) |
Insane Poster Join Date: Jun 2004
Member: 68316 Status: Offline Thanks Meter: 6 | RAZR2 V9 unlock problem Please ensure that you have used and.... Searching for phone... found S Flash Argon, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 4.C1 Sending boot... OK Processing data, 6 of 6 block...OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Argon Switching to flash mode... OK Reading phone boot version... 4.C1 Phone is in flash mode now. Please help |
11-15-2007, 13:19 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ MIKES, It looks like Cable is faulty or Prepare Smart TestPoint procedure wasn't performed properly. Please tell us what cable you are using. Where did you purchase it? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-15-2007, 13:44 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ MIKES, Check this link, please. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-15-2007, 15:01 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ MIKES, You can try to flash the handset with the same firmware version like it has via *.pcf file using SCout flasher. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-15-2007, 15:22 | #8 (permalink) |
Member: 68316 Status: Offline Thanks Meter: 6 | Preparing firmware image... Loading RAM downloader for bootloader... Error checking the RAM Downloader. Error jumping to RAM Downloader Flash failed Flash completed with error/warning: Flash library error 159 |
11-20-2007, 17:00 | #11 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | What is firmware version of your V9 and what flash file have you chosen for flashing? Phone info can be found in the Motorola -> 'Phone details' bookmark. |
12-03-2007, 01:55 | #12 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Galaxy far far away!
Member: 6428 Status: Offline Thanks Meter: 43 | Will somebody please help me how to get the pinouts RAZR2 V9. Or is there somebdy can tell me where to buy this type of cable because I got here a piece of RAZR2 V9 but I dont have the data cable/usb cable even the owner. Only phone itself. No usb cable. V3 usb cable is dirrerent from V9 usb cable. |
12-03-2007, 10:39 | #13 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Dj King, The box with this handset contains data cable. In case if you are looking for Smart TestPoint cable, schematic for it can be found here. Alternatively Smart TestPoint cable can be bought from www.gsmerver.com. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-03-2007, 15:21 | #14 (permalink) |
Member: 6428 Status: Offline Thanks Meter: 43 | @Tinkertrain Unfortunately the owner said that the phone was came from U.S. and was shipped here in the Philippines without box, manual and usb cable. So, I dont know where to get usb cable even the pinouts for this phone. I've already got A Smart test point cable and already unlocked several v3xx, m702ig and m702is successfully. What I need now is the phones usb cable schematic diagram or its pinout in order to unlock this type of phone. |
motorola razr2 v9 unlock code pls | nikkiwinter | Phone Unlocking Codes & Maps | 40 | 01-24-2013 12:54 |
v9 unlock problem | gyuszko | Smart-Clip | 2 | 09-02-2008 21:03 |
Motorola RAZR2 V9 unlock possibly? | fingusio | Smart-Clip | 4 | 08-07-2008 13:25 |
help ! v9 unlock problem | nokia_8800 | Smart-Clip | 2 | 07-09-2008 03:46 |
v9 unlocking problem | nafg | Smart-Clip | 8 | 03-06-2008 14:56 |
