11-15-2005, 23:08 | #1 (permalink) |
Junior Member Join Date: Oct 2005
Member: 191877 Status: Offline Thanks Meter: 7 | reading flash id..clip communication failed i have a c650 that when i power it on it goes into flash mode..the phone worked fine before i accidently flashed it with a lower version.i wanted to unbrand the phone..now phone will only go into boot mode normally i would just reflash it with backup but it wont let me..here is the log. Clip serial: *********, version: 2.17, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.B0 Reading flash id... clip communication failed why do i get clip communication failed the phone is new. smart clip team please help i must flash the backup back onto the phone. BR GuilleB Smart Clip On |
The Following User Says Thank You to GuilleB For This Useful Post: |
11-17-2005, 16:44 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Use a testpoint method to flash your phone. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
The Following User Says Thank You to GSM_Support For This Useful Post: |
11-17-2005, 17:00 | #3 (permalink) | |
No Life Poster Join Date: Jul 2004 Location: IN YOUR DREAMS Age: 41
Member: 74749 Status: Offline Thanks Meter: 167 | Quote:
thankx | |
The Following User Says Thank You to falak For This Useful Post: |
11-17-2005, 17:05 | #4 (permalink) |
Member: 191877 Status: Offline Thanks Meter: 7 | have tried testpoint method maybe i made the testpoint wrong..becuz nothing happens when i connect testpoint and click on search for phone the way i mad the test point is i soldered a short cable to chassis and a pin to the end of the cable and then i touch the testpoint with the pin is this correct? BR guilleb |
11-17-2005, 20:01 | #5 (permalink) |
Member: 191877 Status: Offline Thanks Meter: 7 | testpoint method worked ok i was able to flash the hone with testpoint method.now the problem is that i checked overwrite boot area flashed100% ok but phone does not power up not even to flash mode anymore and when it says reading boot version FF FF. i guess i messed up boot area i have flashed 3 more times and tried to overwrite the boot area but it does not fix the problem.is there anway i can fix this BR GuilleB |
11-19-2005, 11:41 | #6 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Try to perform a repair PDS procedure. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-19-2005, 21:12 | #7 (permalink) |
Member: 191877 Status: Offline Thanks Meter: 7 | PDS repair procedure ok this is what i get when i do repair PDS Clip serial: *********, version: 2.18, initializing... OK Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... ST-M58LR128FB Reading flash id/2... OK, none Phone group: C38x,C390,C65x,V18x,V22x Hardware IMEI: 354508004338160 Security area saved to "S Blank Neptune LTE 354508004338160.pds" Login request... OK Writing section0 done Preparing... clip communication failed Searching for phone... found S Blank Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... FF.FF Reading flash id... ST-M58LR128FB Reading flash id/2... OK, none Phone group: C38x,C390,C65x,V18x,V22x Hardware IMEI: 35450272D632168 Security area saved to "S Blank Neptune LTE 35450272D632168.pds" Login request... OK Writing section0 done Writing section1 done Writing section2 done Writing section3 done Restarting phone... OK Searching for phone... found S Blank Neptune LTE Switching to flash mode... OK Repair PDS request... OK Performing PDS repair... error 9B what does this error mean? BR GuilleB |
11-19-2005, 22:01 | #8 (permalink) |
Freak Poster Join Date: Dec 2004
Member: 101818 Status: Offline Thanks Meter: 2 | Standard cable good work http://www.smart-clip.com/pinout_p2k_to_usb.pdf |
The Following User Says Thank You to KAITA For This Useful Post: |
11-23-2005, 11:39 | #10 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | Phone has a technical problem. More likely, flash memory chip has a lose contact somewhere. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by GSM_Support; 11-23-2005 at 11:54. |
clip communication failed at 72% flashing three times | kamransohail786 | Smart-Clip | 8 | 12-03-2007 09:04 |
Clip communication failed at 78%when flashing moto v80 | djouaka | Smart-Clip | 1 | 07-18-2007 08:23 |
clip communication failed while flashing !!!! | bayleaf | Smart-Clip | 1 | 12-22-2005 23:50 |
Motorola C350 smart-clip " clip communication failed | jamsab18 | Smart-Clip | 6 | 01-24-2005 23:58 |
Communication error after reading flash ID on 6610 | Abe | Nokia Digital Core Technology 4 ( DCT-4 ) | 4 | 02-20-2003 09:47 |
