01-03-2008, 00:42 | #1 (permalink) |
No Life Poster Join Date: Jun 1999 Location: Germany
Member: 233 Status: Offline Thanks Meter: 36 | The real Smart Testpoint schematic please " Please ensure that you have used and appropriate Smart TestPoint cable and it's connected properly" My cable looks different, but I have check every part, test every transistor, so cable is 1000% like the schematic from smart-clip.com. Smart-clip team allways say only our cables are good, I never hear this from a other team for a simple cable. Its easy to publish a wrong schematic and then say use only our cable. So please post the real schematic I use Smart-clip for 4 years now, never had any problem until now, I am also sure that testpoint 100 % correct. Now have a dead phone, all flashfiles that I found get Error 0x7870 with RSDlite. Thanks Smart-Clip, now I have to pay the customer a new phone. |
01-03-2008, 07:57 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | What exactly cable do you have? Where did you get it from? The correct Smart_TestPoint_cable_schematic.pdf can be found in Public Downloads>>TestPoints section at www.boot-loader.com. All just depends what components your cable is based on. That is why we always recommend using our cables only, as they are based on stable fully tested hardware. Best Regards GSMServer team |
01-04-2008, 08:42 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ jan, In case if your phone was powered on during Prepare Smart TestPoint procedure, then temporary backup supposed to be saved. During unlock procedure via Prepare Smart TestPoint cycle SmartMoto automatically detect backup and suggest to restore it. Press yes. After successfull unlock the phone will be restored. Also, you can flash the the phone with *.mfw files via Preare Smart TestPoint procedure. To be able to revive the handset it should be flashed with the original firmware version or higher one. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-05-2008, 02:07 | #5 (permalink) |
No Life Poster Join Date: Mar 2005
Member: 127049 Status: Offline Thanks Meter: 49 | you need to buy the right smart-testpoint ,made from smart-clip here www.unlockcellular.com or www.gsmserver.com, then try step by step again,,don't need to flash now,,, if smart-testpoint made from differant than smart-clip,,,not working at all,,,,don't go through then phone always in bootloader good luck mate |
01-05-2008, 10:09 | #8 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Space
Member: 352237 Status: Offline Sonork: 100.1577161 Thanks Meter: 605 | download from support area go to www.boot-loader.com and login with smart clip and then u can download flash files |
v3x testpoint with smart testpoint | cingularv551 | Smart-Clip | 1 | 10-27-2008 08:17 |
Improvements to the Smart TestPoint Cable schematic | GSM_Support | Smart-Clip | 0 | 09-21-2007 13:42 |
Z-105 the Real for sure pinouts please. | shuttle4 | QUALCOMM Models (3G) | 1 | 09-01-2006 21:42 |
Admins, please tell me who is the real reseller of this UFS? | JFK | UFS2 + UFS3-Tornadoflasher | 4 | 04-02-2005 14:23 |
Please help!I need the real solution for dead GD52!!! | starpho | Panasonic | 0 | 04-27-2001 04:21 |
