05-20-2006, 12:00 | #1 (permalink) |
Major Poster Join Date: Nov 2004 Age: 44
Member: 93109 Status: Offline Thanks Meter: 0 | really really need help for unlocking v3x!!!! I posted problems with v3x unlocking before but seems no one can help... Anyway, I've managed to unlock 2 v3x before, struggle to connect many times and they worked. I've got another one today, and I have been trying to connect testpoint for nearly 2 hours!!!!!!!! Still no success. I used cruiser K750i cable with the 2 clips (black and red) I cliped a needle into one clip and connected the other to the metal case of smart clip for grounding. I also tried ground with the sim card slot, nothing worked. But before I used the same method and done 2 phones with many trials. Could anyone give me some advise on the tools I need to be using??? Really don't know if it's my tools are not good or my smart clip doesn't want to work!!!!! HELP!!!!HELP!!!HELP!!! Here's my smartmoto log. SmartMoto 1.19 Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... clip communication failed Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola P2K, getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Searching for phone... no phone found Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... clip communication failed Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... no phone found Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... no phone found Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... no phone found Clip serial: xxxxxxxxx, version: 2.24, initializing... OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... clip communication failed Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... AT command error Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK |
05-20-2006, 12:03 | #2 (permalink) |
No Life Poster Join Date: Feb 2003 Location: In My Pub
Member: 307549 Status: Offline Thanks Meter: 188 | Its not the test-point that's the problem, AT command error if i'm not mistaken means they is a user code on the handset that needs to be removed and the you should be able to connect to the phone |
05-20-2006, 12:11 | #3 (permalink) |
No Life Poster Join Date: Mar 2004 Location: South Coast UK
Member: 58075 Status: Offline Thanks Meter: 17 | Cruiser cable do what?? What you doing with that? Use USB cable connected to smart-clip, I use ground on PC chassis. Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK This would imply to me that you have not followed the correct procedure Connect USB Connect TP Connect Battery Search In smartmoto Disconnect TP and unlock |
05-20-2006, 12:33 | #4 (permalink) | |
Member: 93109 Status: Offline Thanks Meter: 0 | Quote:
when smartmoto says "AT command error", I'll just click "search" again right after that, it will then connect ok. Don't know why. | |
05-20-2006, 12:36 | #5 (permalink) | |
Hi, I used usb cable for smart clip, the cruiser cable I used for connecting testpoint. The K750i cable has 2 battery connector, I used them. The procedure I did was, connect smart-clip to the computer connect usb cable to the phone power the Smart-clip on Connect testpoint connect battery Search in Smart moto By the way, sometimes smartmoto says phone not found. Then the smart clip leds red, and I have to unplug the power and then replug it because if I keep searching, it will still say "no phone found". | |
05-20-2006, 14:33 | #6 (permalink) |
Member: 58075 Status: Offline Thanks Meter: 17 | I think using cables from cruiser cable to me seems a bit dangerous also grounding to smart-clip box because these devices go into USB 5v and all sorts of circutry and I would not feel to confident with this for GND method . I have done 2 V3x today only problem I had was no LCD but fixed with reflow TP Could be problem with your smart-clip but I would use a different method for GND |
05-20-2006, 14:46 | #7 (permalink) |
Member: 93109 Status: Offline Thanks Meter: 0 | what method do you use for GND? Because I read lots of threads regarding V3x and found someone using the smart clip case for GRD and some one use the sim card slot(metal shield) for GRD... The cruiser cable part I used is just the 2 claws (battery connector), dont' think there should be any problem about that. Just now I tried another dozens times for connecting, still no luck. I've already connected hundreds of times in total, so I'm pretty sure I've learned some skills and hand is steady, didn't move at all when insert battery. So weird! I'm in Australia, and just found out the only official reseller here doesn't sell Smart clip any more...... I'm Really seeking support! |
05-20-2006, 14:51 | #8 (permalink) |
Member: 307549 Status: Offline Thanks Meter: 188 | You are not connect the test point to the ground coreclty mate You should see something like "getting test interface... interface not found" and not "found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x" |
05-20-2006, 14:53 | #9 (permalink) |
Member: 58075 Status: Offline Thanks Meter: 17 | V3x no 3 today just done while reading this post SmartMoto 1.20 Clip serial: lololololol, version: 2.25, initializing... OK Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.10 Reading bus width... OK Reading flash id... Intel-28F256L18B (x2) Phone group: E770,E1000,E1070, V3x,V975,V1050 Hardware IMEI: 35739000xxxxxx6 Security area saved to "S Blank Rainbow POG 35739000xxxxxx6.pds" Unlocking phone... OK notice the part Searching for phone... found S Blank Rainbow POG, getting test interface... interface not found Switching to flash mode... OK and your part Searching for phone... found Motorola Phone (RAZRV3x), getting test interface... OK Model RAZRV3x Firmware R25221LD_U_85.83.E9P Reading info OK yours is not going into flash mode so this is TP problem is phone off? |
05-20-2006, 15:18 | #10 (permalink) | |
I know the difference, I've unlocked 2 v3x before, and I kept trying and trying just want to connect it with "S Blank Rainbow POG", but it just kept coming up "Motorola Phone (RAZRV3x)". Theoretically it's the problem with my TP connection, but I just don't know what's the best tool for TP. Could you tell me what do you use for TP connection to GND? | |
05-20-2006, 15:24 | #11 (permalink) |
Member: 58075 Status: Offline Thanks Meter: 17 | I solder wire on using old 80 pin IDE cable, lead free solder and 12w antex iron 0.12mm solder tip, some flux (chinese stuff) and tape over to stop movement, then when need TP connected I connect to other wire attached to my PC chassis screw, unlock then de solder |
05-20-2006, 15:32 | #12 (permalink) |
No Life Poster Join Date: Jan 2005 Age: 50
Member: 104911 Status: Offline Thanks Meter: 42 | its no wonder people have problems when they solder wires to testpoints. very,very,very easy, just use a normal scope/test probe and touch it on the testpoint, click search, take off probe, pick up cup and drink coffee while waiting for it to finish unlocking. works on every motorola/se phone. phone opened unlocked and put back together in 5 mins, test on nearly 200 v3x's now without any problem. i really don't know why its so hard. br Last edited by James-R; 05-20-2006 at 15:44. |
05-20-2006, 15:56 | #13 (permalink) |
Member: 58075 Status: Offline Thanks Meter: 17 | No problems with solder here even sagems I solder - much better than jigs if I use probe I have to hold phones in awkward positions soldering is a much better connection this guy @hyds is having probs with his TP so solder is much better solution for him How do you combat the awkwardness of using a probe? |
05-20-2006, 15:58 | #14 (permalink) | |
Looks like my method isn't good enough! I dont' have the scope/test probe like you said, any chance you could upload a picture so I know what it looks like? I know v3x should be easy to unlock, I don't know why it's so hard either! I'm off to bed now, tomorrow I'll see how it goes. THank you guys | |
05-20-2006, 16:03 | #15 (permalink) | |
I've done it hundreds of times and I can handle it alright now, very steady.... But doesn't work!~~ I don't have a solder, guess I have to buy one tomorrow lol! By the way, how do you de-solder the wire when it's done? Sorry it may sound stupid, just because I never done solder before. I'm off to bed now. Will come back here tomorrow morning. Thank you | |
SiRoYa please help me. i need help for unlock A707 | IkaMazini | UST Pro II | 3 | 11-23-2007 12:02 |
Really need help for my V3x | fucoco | Motorola P2K (USB-Smart) | 6 | 04-24-2006 04:21 |
!!! HELP !!! I need help for unlock 922--FT4,1M:1803 | KisaKot | Infineon C16X M51 & ARM7 M52 BASED | 3 | 07-25-2002 03:27 |
I need HELP for UNLOCK my Phone T2288 | Kozlik | Motorola Old Legacy (EMMI) | 0 | 07-20-2001 22:09 |
I need HELP for UNLOCK my Phone T2288 in CLONE MODE | Kozlik | Motorola Old Legacy (EMMI) | 2 | 07-20-2001 19:36 |
