Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 07-28-2004, 15:51   #1 (permalink)
BadUnlockers's Avatar
Member: 44610
Red Light on Cxxx Series
I've had this prob on few fones.... after i hit unlock button after 2-3 secs redlight..
Could this be Cable Prob?? Phone Prob?? or Clip Prob??
waitin 4 replies.
Didi
Old 07-28-2004, 16:24   #2 (permalink)
Member: 32195
make sure the phones batterys are charged...
Old 07-28-2004, 19:27   #3 (permalink)
thecult's Avatar
Member: 9700
1. phone batt charged
2. security code deactivated
I have unlocked a lot of cxxx withouth problems with this great tool
b.r.
Old 07-28-2004, 20:38   #4 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Use 9V Charger in Smart-Clip which u use for Griffin !!!
Problem will be Solved
Old 07-28-2004, 22:30   #5 (permalink)
ChouChou's Avatar
Member: 53113
waitin 4 replies.
Didi
Same problem whit c550
I did use 3 deferent battery and 2 deferent charger 9V but the same. I turn on the clips after that I turn on the phone and connect it to the phone and I click on unlock and the phone restart and the clip give me the red light….
Do you think that the software version in the phone is not supportet in the clip??
Old 07-29-2004, 06:57   #6 (permalink)
ssatcom's Avatar
Member: 17098
I have the Same problem.
after Red light dont remove cable,again power on phone press unlock button
now u got green light .this method work with me.
Old 07-29-2004, 07:06   #7 (permalink)
ssatcom's Avatar
Member: 17098
Thanks for the new Update. Success fully Unlocked A835 Motorola 3G phone.
Thanks SmartClip Team.
Old 07-29-2004, 07:38   #8 (permalink)
DMD
DMD's Avatar
Member: 12660
@ All Smart-clip users
My experience with Smart-clip is on some handsets its all about timing some connect 100% ok when on, some connect 100% on startup logo and sound.
WBR D.
Old 07-29-2004, 15:43   #9 (permalink)
Member: 8970
Me too can't unlock C550 with smart clip. pls how to do
Old 07-29-2004, 18:28   #10 (permalink)
Member: 44610
U see @ least itz not only me that has this prob.... I tried all methods said here ealier on ... even plug charger then unlock but none solved... btw some phones work perfectly while some gives that Red light.
@ ChouChou
I'm not sure of that... Ok i tried reading flash but no way... cant even connect to SCreader.
CONFUSED..
Old 07-29-2004, 19:54   #11 (permalink)
Member: 75528
i have same problem with C450, and can not read flash (error entering flash mode...54)
it looks like smartclip failed to switch phone in right mode for unlocking
tryed two different power adapters, three phone batteries and two C450
Old 07-29-2004, 22:20   #12 (permalink)
Member: 17259
new update in server , c series problem solved :-)
great support!
Old 09-08-2004, 08:07   #13 (permalink)
Member: 19115
i try to unlock c350 but it fail ! when i try to read flash it show ''failed [59]'' ! cam anyone tell me what problem?
Old 09-14-2004, 10:27   #14 (permalink)
Mansoor's Avatar
Member: 45561
if you are using firmware 1.18 it can not work smothly in cxxx models so update your firmware to the lastest firmware i used to get same problem sent result
Old 09-15-2004, 07:26   #15 (permalink)
taopheek's Avatar
Member: 44566
Well No One Has Talked About The Connecting Port Sometimes U Just Hane To Clean It Thoroughly And It Works Betterstill Get The Latest Update My Own Prob Is The A920 Different Strokes For Different Folks
T303 unlock dead,only to show red light on power on. Ducdung76 DreamBox 5 09-09-2009 13:01
DEAD W850i ONLY RED LIGHT ON THE ON OFF SWITCH vilas_vanjari Seking Server 3 04-01-2008 09:11
T630 only red light on joystick??? bhgsmservis Sony Ericsson Hardware Repair Area 0 09-03-2005 13:32
red light on v150 Mounir Smart-Clip 0 08-26-2004 18:59
A800 red light on then put the bettery. Any ideas ??? Mobitel_nn VLSI, Conexant, Skyworks and Old Models 7 11-17-2003 12:36
Page generated in 0.36939 seconds with 11 queries
