Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 01-29-2006, 19:29   #1 (permalink)
Member: 226496
Regarding External powering of phones for TP
I have a powerline universal ac adapter 3-12 volts DC 600/ma.
It uses a switch to go betwen 3-12 volts and has a seriers of little plugin adapters that you change for each voltage setting. for example the 9v plug fits my smart clip.
My question is can I use this to power phones during the TP procedures??
Can I just remove the plug, set the switch to 3 or 4.5 volts then insert leads (with gator clips on the other end) into the 2 holes and then attach the clips to the battery posts on the phone?
If so I see that the phone has 4 posts 2 pos 2 neg I presume?
Can I just clip to 1 of each or do I need to clip both pos and both neg?
I'm working with a V3x btw.
Also I see that the wire from the ac adapter has 2 leads one is all black with writing on it and the other is black with white stripes going down the side. which of those is pos and which is neg?
I'm not much of an electrician so any help is appreciated.
Thank You in advance.
Old 01-29-2006, 23:07   #2 (permalink)
needi's Avatar
Member: 18303
All you need is a multitester or multimeter....to check the polarity on ur Adopter (positive and negative).Yes you can use external power supply to power up phone for unlocking.Check fones battery which points r postive and negative.But there is one thing u must remember....the adopters which doest have regulated out put...can seriously damage the fone.
If ur doing V3x...there is an easy way to do after connecting TP...you can put the board in the back cover only to hold the battery.A little of common sense is needed always.
Old 01-29-2006, 23:28   #3 (permalink)
UHK
UHK's Avatar
Member: 13737
Sonork: 100.100725
for U6 and L6 no need battery or external power tested on planty Fones
connect Tp to Grd and than usb cable find fone Either Mss4 or smart clip
and than Disconnect thats all
can ask alot of other fones unlocking tricks by Pm me
or msn etc
regards
UHK
List of phone for Genie's BB5 unlocking and bb5 logger xpmobile Genie Universal 28 01-12-2010 20:00
Here you can find universal codes for some type of phones. For unlock codes Mr/konsowa Various 27 09-21-2007 01:59
Tons of phones for sale as a LOT Jokez guy Sell ur Old and Used Stuff 2 05-27-2007 21:53
Joblots Of Phones For Sale KATCH Sell ur Old and Used Stuff 0 04-21-2006 18:55
I neeD urgently of cable shematics for external power supply 9v for cable for OTE 3X doky Alcatel & TCL Old Models 0 02-15-2002 06:39
Page generated in 0.29882 seconds with 11 queries
