Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 01-01-2006, 11:51   #46 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
Flash
Originally Posted by micmac
where is it the full flash for v980 firm 83.38.38 ????
Hello
I find That version of flash But is For PST so if You need It Contact i will send You some link ......
All the Best In New 2006
Mario
Old 01-04-2006, 15:58   #47 (permalink)
ViperGSM's Avatar
Member: 49634
Sonork: 100.1671023
Thanks Meter: 71
i solved error 80 with your procedure,thx for great support
i made a serbian translation of latest smartmoto,contact me if you are interested in implementing it in next version,i can do that really fast
Old 01-07-2006, 02:34   #48 (permalink)
wynasoft1's Avatar
Member: 101769
Sonork: 100.95669
Thanks Meter: 68
well my v980 still dead nothing work test point not work i dont know what can i do.
http://forum.gsmhosting.com/vbb/show...35&postcount=1
any ideas
best regards
Old 01-08-2006, 14:03   #49 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
V980
any ideas
best regards
Hello
Try to use repair cable with external power supply. mario
Old 01-10-2006, 07:22   #50 (permalink)
raman_mlp's Avatar
Member: 14442
Thanks Meter: 4
Hi
i got V980m 83.38.38for unlock,
as said in forum, i select V975 and tried to remove RSA,
after removing rsa,phone goes dead...
then i repair pds as v975,pds repaired .
now the phone can't flash with 83.28.38 full flash,32mb flash can't with 64mb memory
so i flashed with R245_U_82.31.56I
after flash with this full flash file using smartmoto,phone gets On but without display
i also have full flash for V980m 83.38.38 org,but i can't flash it with rsd2.3 or pst,
always error while erasing upto 10%
i think now i needed V980m 64mb 83.38.38 flash file for smartmoto,to revive my fone
sc team ???
Old 01-10-2006, 08:51   #51 (permalink)
raman_mlp's Avatar
Member: 14442
Thanks Meter: 4
Problem Solved
phone is working fine now
Thanks
Old 01-11-2006, 11:37   #52 (permalink)
Member: 11273
Thanks Meter: 14
V980m totally dead
Originally Posted by Jankovic
Hello
Hi mario
Do you mean that USB cable what came with SC with 2 connections (Red & Black)? I tried with 9v. Battery but no success to full flash dead totally V980m, it will not go ON or in flash mode after trieng to remove RSA Smart-Moto shows "Connection Failed" but phone still showing "SW updating" after 10 mins. it went OFF and never ON. please help me
Best Regards
Old 01-11-2006, 21:52   #53 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
About Repair cable
Originally Posted by ab1009
Hi mario
Best Regards
Hello
Yes That is repair cable For motorola phone just Check PIN 13-14 most be Short if not make it .. And After That Put repair cable On Phone And Connect max 5v on RED /Black conector After That just try POWER ON without * and # because when You have PIN 13-14 short Phone Go automatic In Flash mode and for flashing i use PST or RSD lite ....
Mario
Old 01-11-2006, 22:17   #54 (permalink)
Member: 21885
Sonork: 100.58861
Thanks Meter: 14
Mario,i didnt forget
i will visit you soon
Roman
Old 01-12-2006, 16:46   #55 (permalink)
adrianw23's Avatar
Member: 189499
Thanks Meter: 16
Hallo, my V980m after rsa V975 and flash R245_U_82.31.56I have proble with network, where is problem, I reset full flash and reflash and this is nothing work , can anybody have this same problem ??
Old 01-12-2006, 17:35   #56 (permalink)
micmac's Avatar
Member: 10396
Thanks Meter: 32
Thanks
how are u solved this pb NO DISPLAY
explain plz
Old 01-13-2006, 00:29   #57 (permalink)
Member: 9887
Hi all
please help mi.
after TP motorpla V980m is dead
Old 01-13-2006, 06:50   #58 (permalink)
Tadiwa's Avatar
Member: 46042
Sonork: 100.1575650
Thanks Meter: 93
i did one v980m without any problem yesterday
Old 01-13-2006, 14:41   #59 (permalink)
senkron24's Avatar
Member: 15880
Sonork: 100.1612155
Thanks Meter: 452
perfekt mannn thanks work gerat big thanks mann
best regarts senkron24
p.s: pls smart team remove this bug
Old 01-15-2006, 17:16   #60 (permalink)
Member: 36035
Thanks Meter: 8
Originally Posted by Gsmserver
For new models V980M with boot 6.31 which give message <Erasing flash memory error 80> during Remove RSA procedure do the following:
1. Select V975 in RSA-protected models list
2. Press "Remove RSA" button. It will promt to continue process. Press YES.
Correct process will start.
Smart-Clip team
Test it!
Correct work!
RSA in V980M ..:: i-MAX ::.. Smart-Clip 2 08-16-2006 18:13
V980m stop during remove RSA bleck Smart-Clip 6 04-24-2006 10:41
Motorola V980m... after remove rsa... keypad not function Chryse Smart-Clip 5 12-07-2005 21:31
remove rsa for v980m yargich Smart-Clip 1 12-06-2005 13:46
Page generated in 0.28754 seconds with 10 queries
