Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 01-25-2009, 11:05   #1 (permalink)
yobb's Avatar
Member: 337450
Rokr E6 Security Code
hi,
Smart clip supports this unit?
Old 01-25-2009, 11:52   #2 (permalink)
vmin81's Avatar
Member: 304251
did u try info with scout software
The Following User Says Thank You to vmin81 For This Useful Post:
Old 01-25-2009, 11:57   #3 (permalink)
R@jusat's Avatar
Member: 745721
Sonork: 100.1605292
just press service tab & reset setting ,hope problem solved
Old 01-25-2009, 12:16   #4 (permalink)
yobb's Avatar
Member: 337450
Phone can't be detected, i used phones cable....
S-Card: 83yobb Smart-Clip dongle, v 2.10, assigned Smart-Clip: 89yobb Europe, initializing... OK
Clip serial: 894yobb, version: 4.08, initializing... OK
Searching for phone... no phone found
Searching for phone... found Phone, getting test interface... interface not found
Switching to flash mode...
interface not found
interface not found
Old 01-25-2009, 14:51   #5 (permalink)
Member: 289366
Moto E6 User Code Solution
1: How to put in boot loader mode?
2: Downlaod Rsd and E6 Flash file
Flash file:
RapidShare: Click here
Rsdlite:
Instructions:
1st install the p2k driver
open rsd and then put phone in to the boot loader mode
then flash with moto E6 Flash
(note: don't disconnect phone during flashing)
br,
The Following 5 Users Say Thank You to marcsantos For This Useful Post:
Old 01-25-2009, 14:53   #6 (permalink)
sahil2000ind's Avatar
Member: 269044
Sonork: 100.1590584
Flash file:
Rsdlite:
Instructions:
br,
AFTER FLASHING WITH THIS FILE IT BECOMES CHINESE SO BE CAREFULL
WE WANT A STANDALONE USERCODE OPTION
WBR
sahil2000ind
The Following User Says Thank You to sahil2000ind For This Useful Post:
Old 01-25-2009, 15:19   #7 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Originally Posted by yobb View Post
hi,
use scout software download from here
just power on the handset conecct to computer usb port after these give proper drivers and wait for one minute and it will show phone code
The Following User Says Thank You to frnd_4_gsm For This Useful Post:
Old 01-26-2009, 10:21   #8 (permalink)
yobb's Avatar
Member: 337450
even i don't have scout dongle?
Old 01-26-2009, 10:39   #9 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
@ yobb,
If you have S-Card, then you can use it with the SCout flasher.
It can be used instead of SCout dongle.
Best Regards
Smart-clip team
www.smart-clip.com
www.scoutdongle.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post:
Old 01-26-2009, 11:18   #10 (permalink)
yobb's Avatar
Member: 337450
Done with Scout Software via S-card.
whewwwwww!
Info was read but when entered to phone wrong code....
Master Reset do the Job!
Thanks to all who replied...
Old 07-13-2009, 13:33   #11 (permalink)
cgsm's Avatar
Member: 88402
Flash file:
Rsdlite:
Instructions:
br,
pls mention the rar password.
The Following 3 Users Say Thank You to cgsm For This Useful Post:
Old 03-30-2010, 18:03   #12 (permalink)
Member: 1056266
Sonork: 18051
Motorolo E6 RESTART problem
Sir.
if i click master reset it gives this error message i post the log here plz help sir
Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found
Switching to flash mode... OK
You have to reconnect phone test interface for this function to work
THANK YOU
Old 03-31-2010, 07:11   #13 (permalink)
GSM_Support's Avatar
Member: 121052
@ mobilesaran,
You connect the phone in flash mode or in normal mode?
Also, please tell us what software did you use.
Best Regards
GSMServer team
Old 03-31-2010, 09:45   #14 (permalink)
cellexpert's Avatar
Member: 857876
Sonork: cellexpert-33
better use mss 4 this problum remove user code 2 sec......................................
Old 04-01-2010, 14:09   #15 (permalink)
Member: 1056266
Sonork: 18051
Sir
Sir i am using smart clip
And i connect the phone in flash mode And also Normal mode Sir Same problem
Thank you.
Motorola ROKR E8 security code unlock. jebama Scout 1 08-25-2009 10:11
how to read motorola E6 security code Mohsin-* Smart-Clip 1 01-01-2009 10:02
Moto Rokr E6 touchpad not work Rajgreat P2k Series 1 07-28-2008 09:22
Moto Rokr E6 Softwares mann_s_love P2k Series 0 05-07-2007 17:03
HOW TO UNLOCK Motorola ROKR E6 rajtelecom P2k Series 0 04-23-2007 22:36
Page generated in 0.71638 seconds with 11 queries
