11-12-2008, 16:58 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ pearsonjohnboy, S-Card Driver for Win2000/XP v.3 is newer version of the drivers for the dongle. They suppose to be used in case if version 2.0 can not be installed. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
11-13-2008, 08:41 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ pearsonjohnboy, You can use any of those drivers. If V.2 drivers doesn't work install V.3. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-13-2008, 10:18 | #5 (permalink) |
Insane Poster Join Date: Jul 2005 Location: Germany Age: 46
Member: 159805 Status: Offline Thanks Meter: 1 | @Mr.Tinkertrain thx for this info, i just install this driver v.3. then connect scard dongle in pc usb port and smart clip via lpt-port. I start smartmoto, click search and then got this error msg SmartMoto 3.18 S-Card: 39xxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: 92xxxxxxx Europe, initializing... OK Reading serial... error 45 you have any idea, whats wrong here? |
11-13-2008, 10:45 | #6 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ punktde, Please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. LPT port settings are set to EPP in BIOS 3. Your LPT cable works properly 4. You use a stable power supply with your clip (use power adapter 12V 750mA) 5. If you are using WinXP, log in as Administrator or any other account with administrative rights To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SmartMoto, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
about MT CPU what the different between MTK_ver and MT_Expanded | dharyadi | CPF-BOX Ⅱ | 2 | 02-26-2010 16:07 |
what the different between Orginal and custom firmware?? | saiftc2 | iPhone 2 / iPhone 3G / iPhone 3GS | 3 | 01-27-2010 21:23 |
Whats the difference between Tornado and Twister? | GeeZuZz | Twisterflasher | 11 | 06-02-2005 20:12 |
What the difference between A38 and COMP128? | nomen. | Sim Cloning and Scaning | 1 | 06-28-2004 06:36 |
what is the difference between v1 and v2 codes? | im2fn6e | Phone Unlocking Codes & Maps | 5 | 07-29-2003 05:43 |
