12-22-2006, 17:27 | #1 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 53
Member: 4611 Status: Offline Thanks Meter: 68 | s-card not identified Ran smartmoto. It also sees the clip and key correctly but will not run until the key is updated......Please help me. Hopefully gonna be a very good day on Saturday. |
12-22-2006, 17:49 | #3 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Hmm. The key was working 30 seconds before with smartmoto. Now I have updated the clip, I now find the key will not update. It registers with smartmoto fine....It has to be either software or drivers. Re-seller I doubt can help here. |
12-23-2006, 00:28 | #4 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | hi we are having same problem, check threat http://forum.gsmhosting.com/vbb/showthread.php?t=359299 best regards Invisible |
12-23-2006, 00:42 | #5 (permalink) |
Freak Poster Join Date: Jan 2006 Location: United Kingdom
Member: 219568 Status: Offline Thanks Meter: 0 | uninstall the smart card updater software and download the new version from the website for some reason it will say v1.3 but it is v1.5 thats what i did then you cn update the card its like smartmoto first you have to uninstall and install new ver good luck |
12-23-2006, 01:06 | #6 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Installed the lot on a brand new machine... Still exactly the same. From what Invisible says "post help" I'm beginning to think I'll have to use the "free" server from another vendor until after christmas. Blimey. I don't even mind buying a new s-card (if thats possible). New updating the clip this close to christams was a bad idea. Thanks for your advice anyway. |
12-23-2006, 01:59 | #7 (permalink) | |
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | Quote:
update client is version 1.3 which had been there from half december, version 1.05 is the scard firmware itself, problem is for some reason the card did not update "something" inside at the end of the process, best regards Invisible | |
12-23-2006, 10:32 | #8 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Please write a letter to support[at]smart-clip.com in letter please specify serial number of your S-Card, Smart-Clip, explain what problem you have and attach log files and screenshots. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
12-23-2006, 11:11 | #9 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Thanks for the reply. I am beginning to think however that it is a standard cut 'n' paste reply. I have sent as much info as I can to the above address, and realise now that I will have to use other means to try and work this (trade) chritmas eve. I like using this clip, and have very little doubt in its ability. It is wrong that myself and many other people's only fear is when you try and update it. It would be better if precautions could be made. I'm sure there are many little ideas for them. But regarding skey updating after you update the clip, would it not be better, that the previous Smartmoto would still be able to work so your not left with a useless box. |
smart clip registration fail and s-card not identify | UHK | Smart-Clip | 19 | 06-29-2007 19:28 |
S-Card not identified, little help needed GsmServer | Invisible | Smart-Clip | 11 | 06-11-2007 07:26 |
Smart Card Not Identified While Update | shahjee | Smart-Clip | 1 | 01-20-2007 10:44 |
s-card not identified | Cake | Smart-Clip | 1 | 01-11-2007 08:23 |
S-card Not Identified | tikal | Smart-Clip | 2 | 01-03-2007 11:22 |
