Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #3 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2004 Location: Elaioun-Berkane to netherland Age: 37
Member: 58969 Status: Offline Thanks: 4
| Quote: when i search by smartmoto V3.20 for smart clip i get Smart-Clip dongle blank, v 0.00 Last edited by Mounir; 03-11-2009 at 14:20. | |
| | #4 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Thanks: 425
| The dongle simply has to be updated. S-Card registration/update procedure Please be aware that S-Card registration/update procedure requires a stable Internet connection during the whole process. 1. Connect S-Card dongle to PC USB port; 2. Connect Smart-Clip to PC using Smart Adaptor or LPT cable; 3. Power Smart-Clip ON (warning: don’t use battery!); 4. Go to our Update Zone; 5. Update Zone uses ActiveX control, answer "Yes" to install and run it; 6. Log to the S-Card tab; 7. Press "Update" button; 8. An ActiveX client should detect Smart-Clip serial, firmware version and S-Card serial, update process begins; 9. New firmware is loaded. Best Regards GSMServer team |
| | #5 (permalink) |
| S-card firmware version is 0.00 when i press update smat-clip update Smart-Clip update software 3.05 Warning: make sure you use power adapter! Clip serial: 4527xxxxx Firmware version: 4.08 login... OK Server firmware version: 4.08 European market Smart-Clip Clip warranty period: 17-Nov-2004 to 16-May-2005 (expired) EEPROM test successfull,reporting... OK Checking dongle... OK Smart-Clip dongle blank found, serial 218xxxxx Smart-Clip doesn't need update -S-card update Smart-Clip update software 3.05 Warning: make sure you use power adapter! Checking dongle... OK S-Card serial 2185xxxx S-Card identified You can Register your S-Card now. Your S-Card will be updated automatically Clip serial: 4527xxxx Firmware version: 4.08 Last edited by Mounir; 03-11-2009 at 15:19. |
| | #6 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Feb 2006
Member: 229997 Status: Offline Thanks: 252
| Please send log files from update zone including serial numbers to support[at]smart-clip.com ___ Best Regards GsmServer Team www.smart-clip.com www.scoutdongle.com www.boot-loader.com |
| | #7 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2006 Location: in the cellphone
Member: 352414 Status: Offline Thanks: 106
| i have the same problem i can not update the s-card smart clip upate is okey so plz do something my clip and s-card is new Last edited by GSM_Support; 03-12-2009 at 08:13. |
| | #8 (permalink) |
| Please send log files from update zone including serial numbers to support[at]smart-clip.com Best Regards GSMServer team |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| problem in s-card update problem | mahesh gandhi | Smart-Clip | 1 | 08-05-2008 08:10 |
| s-card update problem | toptech | Smart-Clip | 3 | 07-06-2007 08:26 |
