11-06-2009, 18:42 | #1 (permalink) | ||
No Life Poster Join Date: Aug 2004 Location: Brazil Age: 44
Member: 77651 Status: Offline Thanks Meter: 21 | SC hardware failure? > Using Battery: Quote:
On second case, If I put in boot manualy I can finish the procedure successfully... kadES | ||
11-07-2009, 10:32 | #2 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | In case of getting an error "Clip communication failed", while detecting the handset, please check the output of Smart-Clip power source. For stable Smart-Clip functions the recommended power supply is 10V, 1A. Some phone models use a data cable for charging. So, as soon as it gets connected to Smart-Clip it starts charging and uses about 500mA, plus Clip requires another 130-150mA. Also, please ensure hat your LPT port is set to EPP mode in BIOS and firewall with antivirus are disabled. Best Regards GSMServer team |
939 hardware failure ,mobile blocked ,what to do? | igor_m | ARM9 BASED M62 / M62+ | 1 | 09-27-2000 08:54 |
Hardware failure for Sagem939... | pavlin | ARM9 BASED M62 / M62+ | 3 | 07-12-2000 13:33 |
"Sagem MC939" Hardware failure repair with power-sound | Sedy | ARM9 BASED M62 / M62+ | 2 | 07-05-2000 08:53 |
Hardware Failure with Sagem MC930 | FireWolf | ARM9 BASED M62 / M62+ | 10 | 06-30-2000 23:37 |
MC939 Hardware failure | saulius_znatavicius | ARM9 BASED M62 / M62+ | 0 | 05-22-2000 09:59 |
