04-23-2008, 07:12 | #5 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ john_john & Celhack, Try to connect the SC to upgrade zone? http://www.smart-clip.com/upgrade.php Does the program detect the Clip? If yes, please send an operation log to support[at]smart-clip.com Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-23-2008, 14:39 | #7 (permalink) | |
No Life Poster Join Date: Dec 2006 Location: NYC
Member: 416710 Status: Offline Thanks Meter: 391 | Quote:
04-23-2008, 14:46 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Celhack, PM me your e-mail address. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-26-2008, 21:58 | #9 (permalink) |
No Life Poster Join Date: Jan 2004 Age: 45
Member: 49581 Status: Offline Thanks Meter: 73 | same here ... clip is dead with Smart-Moto, no light coming up ... SmartMoto cannot detects the Clip, the program will stay at message "Reading serial..." when i click on SEARCH but if i go to Upgrade Zone, it detects the SmartClip, and one GREEN light will come up .. |
05-27-2008, 07:12 | #10 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ gwaai, Please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. LPT port settings are set to EPP in BIOS 3. Your LPT cable works properly 4. You use a stable power supply with your clip (use power adapter 12V 750mA) 5. If you are using WinXP, log in as Administrator or any other account with administrative rights To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SmartMoto, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-27-2008, 18:54 | #11 (permalink) |
Member: 49581 Status: Offline Thanks Meter: 73 | Hi, I am using Smart Adapter .... Sometimes the clip will work if I twist around all cable that connect to the clip ... but only few times ... But the Update Server ALWAYS can detect my Clip though ... I also try to connect to LPT port, same thing, not working ... |
05-28-2008, 07:06 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ gwaai, Please tell us what power supply do you use with your Smart-Clip? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by GSM_Support; 05-28-2008 at 08:45. |
05-29-2008, 01:01 | #13 (permalink) | |
Member: 49581 Status: Offline Thanks Meter: 73 | Regulated Power Supply... I have been using this for 1 and half years, and I tested this power supply when I have the problem with SmartClip ... second question, if I buy 1 more Smart-Clip, can you pair the old Smart DOngle with the new Clip for me?? I had the smartClip for more than 3 years, and I think I need to replace it ... Quote:
05-29-2008, 09:12 | #14 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ gwaai, Please check your power supply. We recommend to use 12v 750mA power adapter with the Smart-Clip. After that try to read any handset via SmartMoto. Also, double check all the settings. P.S. You can use your S-Card with the new Smart-Clip. To be able to use this option, please write a letter to support[at]smart-clip.com In letter specify serial number of both Smart-Clips (old and new one) serial number of the S-Card and explain what had happened with an old one. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
05-29-2008, 22:18 | #15 (permalink) | |
Member: 49581 Status: Offline Thanks Meter: 73 | Ok, I will order a new one ... Thanks Quote:
smart clip dead: how to/can i update my scard only? | djssergy | Smart-Clip | 5 | 07-20-2011 15:29 |
I how to solve this problem | Saulcell | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 5 | 03-30-2010 10:02 |
t29s dead, how to solve | summer_20xx | Old Ericsson Phones & Sony Phones | 0 | 08-10-2009 21:58 |
Smart clip dead off, how to fix it ? | gsmnice | Smart-Clip | 3 | 06-17-2008 07:50 |
Gx22 Dead How To Solved Help | FullFLASHgSMPH | Sharp | 3 | 07-09-2006 03:31 |
