Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 12-10-2009, 04:42   #1 (permalink)
Member: 1086097
Red face Smart Clip problem two months ago
i need help to fix my problem with my smartclip the thing is when i plug the power adaptor ( buy from gsm server 10 v 1 a) the clip turn on tx led and don't find smart moto or update process
attach log of last update process
Old 12-10-2009, 07:16   #2 (permalink)
GSM_Support's Avatar
Member: 121052
@ absalon,
Problems with ActiveX client:
If you have problems running unsigned ActiveX, please open Explorer's menu Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt"
If you encounter problems during update make sure that:
1. Firewall on your computer (or your LAN) is configured properly or disabled
2. You have reliable internet connection
3. LPT port settings are set to EPP in BIOS
4. Your LPT cable works properly
5. You use a stable power supply with your clip (use power adapter)
6. Your IE version is not lower than v5.0
7. If you run update under WinXP, log in as Administrator or any other account with administrative rights
If during update appears the message "Please update client" - you should perform the following: Open your folder Windows --> Downloaded program files. Find a file named CSmartClient_object, delete it, restart your PC and try to update again.
Best Regards
GSMServer team
Old 12-17-2009, 23:00   #3 (permalink)
Member: 1086097
dont show that message and i dont heve problem with activeX
my problem is that i try to update my clip the program show errors something about cmd and dont update right
and worst is that i only one time use the clip and then it star to show the problem, first was the firmware ff.ff then dont update rigth and now only turn on tx led
if the clip dont working i need that you change me the clip (i buy from you and i have three months with this problem when the clip have warranty)
Old 12-18-2009, 07:11   #4 (permalink)
Member: 121052
@ absalon,
Try to perform update procedure, save log file and send it with the serial number to
Best Regards
GSMServer team
UB unlock 6790s successfull first in the world two months ago haiminhk15_sc Universalbox 2 10-23-2009 11:36
smart clip problem MILUTO06 Smart-Clip 0 07-29-2005 04:12
Smart-Clip problem witch flash v220 AndRe DCF-gsm Smart-Clip 6 03-28-2005 09:02
Smart-clip problem after upgrate to 2.05. WillGsm Smart-Clip 2 03-13-2005 03:01
Strange Smart Clip Problem shakeelajmal Smart-Clip 10 01-15-2005 14:26
Page generated in 0.22322 seconds with 11 queries
