01-26-2008, 05:59 | #1 (permalink) |
Freak Poster Join Date: Aug 2003
Member: 36443 Status: Offline Thanks Meter: 0 | Smart clip team help unlock v3re problem |
01-26-2008, 09:08 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ dxm, Please provide us with more detailed information: What cable have you used for unlock procedure? What power supply you are using for the Smart-Clip? Also, please show us log file without serial numbers. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-28-2008, 08:19 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ dxm, This error usually appears if Smart TP wasn't connected properly or the cable that you use is faulty. Please tell us where have you purchased your cable. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-28-2008, 12:28 | #9 (permalink) |
Major Poster Join Date: Dec 2005
Member: 208325 Status: Offline Thanks Meter: 3 | v3RE UNLOCKED NO PROBLEM WITH GSM SMART TP CABLE SmartMoto 3.05 S-Card: 331 Smart-Clip dongle, v 2.02, assigned Smart-Clip: 211 Europe, initializing... OK Clip serial: 211, version: 4.02, initializing... OK Searching for phone... found Motorola Phone (V3re), getting test interface... OK Model V3re Firmware R3442A_G_0E.41.22R Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.C1 Sending boot... OK Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F901A4FAF97926C0.bk_ Searching for phone... found Motorola Phone (V3re), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.C1 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... ST - M58LR256A Phone group: V3re Hardware IMEI: 3564660 IMEI OTP status: locked Security area saved to "PDS for S Flash Neptune LTE2 3564660.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F901A4FAF97926C0.bk_ Restore OK Unlocking phone... OK |
01-28-2008, 12:54 | #10 (permalink) |
Junior Member Join Date: Dec 2006
Member: 419726 Status: Offline Thanks Meter: 0 | cable u r using is not correct its seems simmiler to smart testpoint cable but symatic is diffrent because i had same cable u have and same problem u had then i changed cable and now everything going fine |
To smart-clip team last update big probleme... | .:MESSAD_RA:. | Smart-Clip | 31 | 12-09-2009 00:31 |
L2 after unlock no display smart clip team help | vinay_sharma | Smart-Clip | 3 | 11-02-2007 08:00 |
to smart clip team ;K1 unlock problem | patric | Smart-Clip | 15 | 03-30-2007 16:50 |
L6 & U6 Unlock Problems!!!!!! SMART CLIP TEAM HELP | xelarey | Smart-Clip | 6 | 07-28-2006 13:45 |
@smart-clip team help! | saiful2001 | Smart-Clip | 8 | 02-04-2006 17:58 |
