Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 09-03-2006, 16:36   #1 (permalink)
Member: 55651
Thanks Meter: 2
Smart-clip Test Point Cable That Plugs In To Rj45 Does Any One No How To Make It
I Have Seen On The Internet A Rj45 Plug That Goes Into The Smart-clip And Has A Test Point Cable On The End Does Any One No How To Make It If So Please Post Cheers Dan
http://www.fonefunshop.co.uk/Unlocking/smartclip.htm AS SEEN HERE
Old 09-03-2006, 19:06   #2 (permalink)
Member: 216952
just make an rj45 cable from the ground of the smartclip, look for the pin out of the smart clip. but ground you can find it in the phone.
good luck
Old 09-03-2006, 19:09   #3 (permalink)
Member: 55651
Thanks Meter: 2
good luck
so what is thebest thing to use for the test point cheers dan
Old 09-04-2006, 02:09   #4 (permalink)
.:bono:.'s Avatar
Member: 96141
Thanks Meter: 200
i don't know what they mean about this cable, the magic isn't in the tp wire.
testpoint wire is anything from ground wich have 0 volt and go to ground of the phone or of the box, they are all the same,
i thing maybe they have make a pure ground who hasn't any signal or noise, or maybe it connect itself instead of connecting tp and search then release and unlock.
it's not a big thing.
br
Old 09-04-2006, 20:24   #5 (permalink)
Member: 48048
Thanks Meter: 7
I use a USB cable that has a clip on +5v and a needle on GND.
that way you connect the needle to tp and then clip the +5v on battery + and hit search.. works 100%.
Old 09-04-2006, 20:38   #6 (permalink)
SkyGear's Avatar
Member: 61204
Thanks Meter: 148
moochers..... use a precision hand drill .... drill over the testpoint with a small bit then toutch the testpoint to the side of the heatshield at an angle and works with no problem.....
Old 09-04-2006, 20:39   #7 (permalink)
SkyGear's Avatar
Member: 61204
Thanks Meter: 148
use a pin ....needle .... hell a paperclip if thats all thats available
Old 09-04-2006, 20:42   #8 (permalink)
SkyGear's Avatar
Member: 61204
Thanks Meter: 148
anything metal directly exposed in the phones are normally ground points all heatshields are a great ground and no soddering is requiired (
less dead phones..... if need be ill post pics of all the tools i use to make holes unlock repair etc
Old 09-05-2006, 06:30   #9 (permalink)
Member: 216952
i preffer to solder a thin wire to test point, so i can work the phone with out problem, i have a microscope and good solder so is fast, easy.
I always put the small wire in the charge connector for groung like v3 i left it inside and plug the cable and once i remove i just pull it,....
Old 09-05-2006, 09:47   #10 (permalink)
fonefun's Avatar
Member: 26187
Sonork: 100:77458
Thanks Meter: 290
get one og these test point box's
they power the phone aswell as giving a testpoint cable too !!
http://www.fonefunshop.co.uk/Unlocking/testpoint.htm
Old 09-05-2006, 11:19   #11 (permalink)
Member: 103946
I use a length of thin wire screwed to the corner of the martclip with a pin soldered to the other end.
does any one know how to revive dead GIGABYTE i28 gSmart-i Mang mel HTC & PDA WM( With Touchscreen) 1 02-05-2009 10:54
Smart clip test point in Georgia, Tbilisi Gozha Main Sales Section 0 10-11-2007 09:34
x-nemesis clip does any one now how to make cloned version nokia_dan Sony Ericsson 1 07-15-2005 15:07
Any one know how to make 7650 USB cable Beginner WD2 & APE (Symbian Phones) 0 04-09-2003 03:29
Does any one know how to program the ESN number with nokia 6120? Bert Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-02-1999 10:45
Page generated in 0.18246 seconds with 10 queries
