01-15-2008, 10:03 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ az_liton, Please make sure that: 1. Firewall on your computer (or your LAN) is configured properly or disabled 2. You have reliable Internet connection 3. LPT port settings are set to EPP in BIOS 4. Your LPT cable works properly 5. You use a stable power supply with your clip (use power adapter) 6. Your IE version is not lower than v5.0 7. If you run update under WinXP, log in as Administrator or any other account with administrative rights 8. You should clear cache of your browser and restart the computer. To run a new SmartMoto under WinXP also to update a Smart-Clip please launch the SM-tool, open Smart-Clip bookmark & tick the option "Disable OS parallel port polling (requires reboot)". After that restart you PC. Also set LPT options in SmartMoto to compatibility Windows XP SP2: if you have problems running unsigned ActiveX, please open Tools > Internet Options > Security > Custom Level and change "Download unsigned ActiveX controls" to "Prompt" After that run update procedure once again. In case if some error appears save log file and send it to support[at]smart-clip.com Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
Smart Clip update problem | Steph | Smart-Clip | 18 | 01-15-2013 14:12 |
Smart-clip Update Problem | Naz66 | Smart-Clip | 31 | 05-17-2010 07:18 |
smart-clip update problem | touch_111387 | Smart-Clip | 0 | 07-12-2007 10:41 |
Smart-clip update problems! | hyds | Smart-Clip | 5 | 11-30-2005 09:49 |
Smart clip update problem | haider | Smart-Clip | 16 | 01-08-2005 13:25 |
