12-26-2008, 00:44 | #1 (permalink) |
No Life Poster Join Date: May 2005
Member: 148833 Status: Offline Thanks Meter: 25 | Successfully unlock V3re but doesn't want to power on,HELP,please!! S-Card: xxxxxxxxxx Smart-Clip dongle, v 2.10, assigned Smart-Clip: xxxxxxxx Europe, initializing... OK Clip serial: , version: 4.08, initializing... OK Searching for phone... found Motorola Phone (V3re), getting test interface... OK Model V3re Firmware R3442A_G_0E.43.25R Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.F4 Sending boot... OK Stored temporary backup to E:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F901A6C7E44D158C.bk_ Searching for phone... found Motorola Phone (V3re), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... C.F4 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 0.00 Reading flash id... ST - M58LR256A Phone group: V3re,K1/s Hardware IMEI: 352476021595919 IMEI OTP status: locked Security area saved to "PDS for S Flash Neptune LTE2 352476021595919.mbk" Performing restore from temparary backup file E:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F901A6C7E44D158C.bk_ Restore OK Unlocking phone... OK |
12-26-2008, 01:22 | #2 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | Hi The log looks OK. Even though you dont see the phone powering on...please try this. Insert a full charged battery, and then press power on....wait for 3 mins and connect to SmartMoto and do search. Post a log here of what SmartMoto finds. If you get (phone not found) in SmartMoto.. then remove and re insert battery and put the phone in bootloader mode * + # + power. Check to see if you have bootloader screen appear. Even if you get no bootloader screen..still connect up to SmartMoto and do search. Post here what SmartMoto finds. If all the above does nothing...remove and reinsert battery and connect charger..post here the result. Thanks ! ,smokin |
12-26-2008, 01:55 | #3 (permalink) |
Member: 148833 Status: Offline Thanks Meter: 25 | Thanx Orange Dominica for suggestions! So When I connect the handset with smart-clip it always sayshone not found!!??May be the handset is died :If it is the case,what are lessons that we can get from,a good procedure as everyone can see above,that "novel" operation!!But we still wait to hear from Smart-Clip's Team ?!?!?! |
12-26-2008, 02:06 | #4 (permalink) |
Member: 88701 Status: Offline Thanks Meter: 381 | If all the above still results in (phone not found).... Check with a meter to verify that the TestPoint is not cut ... TestPoint o=======o If TP checks ok...then carefully remove the entire shield over the processor and flash.....clean then inspect WITH a magnifier...dont trust your vision. Good Luck ! ,smokin |
12-26-2008, 22:30 | #6 (permalink) |
Member: 148833 Status: Offline Thanks Meter: 25 | Always : No fone found..and the Tp is not cut.To flash it I don't have flash of this kind of handset!? support is payed!No answer or suggestion from smart-clip Team at all...Then what to do smart-clip's user? |
12-28-2008, 09:43 | #10 (permalink) |
No Life Poster Join Date: Sep 2007 Location: Jalandhar Age: 39
Member: 580966 Status: Offline Sonork: 100.1590311 Thanks Meter: 725 | Accoording to log unlock operation correctly done by you. May be test-point cable faulty/bug in Smart-moto v3.20............ I unlocked many V3re without any problem (but in smart moto v3.14 with Version-2 cable ) W.b.r Karan |
12-29-2008, 09:30 | #11 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ beneto, Please check the PCB of the phone. If the set can not be detected at all, it definitely has some hardware malfunction. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
6020 flashing OK showing test mode on screen with F-bus but not going to power on | makkah mobile | Nokia Hardware & Hardware Repair | 46 | 05-04-2010 06:13 |
5310 local mode but not switch to power on | dessertcell | Nokia Base Band 5 ( BB-5 ) | 2 | 06-14-2009 22:45 |
U880 doesn't want to turn on | jaymdee | LG | 1 | 06-19-2007 22:13 |
6680 - flash done but doesn't want to turn on | matrix_13 | Nokia Base Band 5 ( BB-5 ) | 8 | 12-18-2006 02:01 |
c25 ver. 61 don't want to power on :( | FreeGSM Team | x1x to x45/x50 | 3 | 04-22-2001 02:02 |
