05-27-2007, 07:28 | #1 (permalink) |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Trick How To Unlock Using Preparephone Connect powered ON handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC). Connect S-Card to PC USB port. Connect power supply to Smart-Clip and power on the handset. Launch SmartMoto. Choose "Smart-Clip USB port" in phone connection window. Press "Search". The software should perform the following steps: SmartMoto detects S-Card; SmartMoto detects Smart-Clip; SmartMoto detects the handset and reads all phone information. Log to bookmark "Prepare". Select the appropriate model from SmartMoto list. Make sure that phone model and boot version of the phone to be unlocked exactly match the model and boot version stated in the list. For unlock purposes, please make sure that "Unlock automatically" option is marked. Press "Prepare" button. The prepare cycle starts. SmartMoto creates a Temporary Backup File* from the handset firmware. For some models, SmartMoto will popup the following instruction to be performed: Remove phone’s battery; Insert battery back; Press power ON; Press ok in SmartMoto; The prepare cycle will continue. At this time popup window appears at SmartMoto interface. Please follow the instructions provided therein Disconnect cable from the phone; Remove phone’s battery; Connect cable to the phone; Insert phone's battery; Press "Power on" key on the phone. Phone's LCD remains blank; Press OK in SmartMoto. The handset should be detected by SmartMoto as "S Blank..." with boot 2.00 (3.00). SmartMoto restores the temporary backup file If the option "Unlock automatically" was marked – the handset becomes unlocked. If the option was not selected then the handset can be served for Flash, Repair PDS, Unlock or Backup purposes. WHY MANY PHONE DEAD....ANY TRICK......THANKS... |
05-27-2007, 08:39 | #5 (permalink) |
No Life Poster Join Date: Jan 2004
Member: 48048 Status: Offline Thanks Meter: 7 | this happens with all L7 when you reinsert battery after the error 80 hold down * and #. do not try to power on the phone. it should work just fine from there. if it asks flash the backup file.. choose yes. the phone will be unlocked. |
05-27-2007, 09:09 | #8 (permalink) |
Product Supporter Join Date: Dec 2001 Location: in my skin Age: 47
Member: 8086 Status: Offline Thanks Meter: 180 | I have done a few L7 and many V360s (which is the same as L7) and newer had any dead phones. "error 80" on smartmoto and "critical error..." on phone's lcd is absolutely normal in every case. Sometimes "MEP Blank..." message on phone's lcd after second battery-out-and-in is a real error, what can be corrected by doing the prepare process again from start (and search the phone) and then choose yes for using the temporary backup for that phone. |
05-27-2007, 09:20 | #9 (permalink) |
Freak Poster Join Date: Apr 2006 Location: MX-KEY is the BEST NOKIA TOOL
Member: 258446 Status: Offline Thanks Meter: 26 | i encounter that ones in V190, just follow instructions, remove / insert battery and power on, the process continues. the backup file will automatically deleted once the phone is sucessfully unlock. Last edited by antee7; 05-27-2007 at 09:45. |
05-27-2007, 10:07 | #13 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Baguio_City;Ph @ DrunkenMaster Age: 44
Member: 51716 Status: Offline Sonork: 100.1594676 Thanks Meter: 217 | http://forum.gsmhosting.com/vbb/showthread.php?t=405597 read and analyze post here from start to end........ para d tayo pagtatawanan |
05-27-2007, 10:55 | #14 (permalink) | |
Member: 258446 Status: Offline Thanks Meter: 26 | Quote:
Sharp 770sh & 550sh! i hve code! need to know how to unlock using codes??? | ReyTech | Sharp | 41 | 05-26-2014 11:35 |
Small trick how to unlock qualcomn phone | luyanda | Z3X-Team Products | 10 | 08-26-2010 18:37 |
alcatel playboy tct does anybody know how to unlock using easy unlocker | TRADER69 | Easy-Unlocker | 1 | 09-09-2009 18:20 |
w200i how to unlock using SETOOL? | BOT_MAY2 | SETool2 | 4 | 09-22-2007 08:35 |
V200 how to unlock using number code? | mazdaspeed_FC | Trident/AGERE Platform | 0 | 05-03-2004 04:42 |
