03-17-2006, 20:59 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Age: 44
Member: 129016 Status: Offline Thanks Meter: 6 | unlock rokr E1 and E770 with NO BATTERY !!! Check diagram I made exactly ... I connect phone no battery to pc usb port , phone goes straight to boot mode. Disconnect 13 and 14 ( no connection between these pins) plug back phone in pc usb port phone boots normally...GREAT !!! Now big problem if use any of the above cable connection on the smart clip usb port the phone does not respond.....May be we can ask smart clip team to make us a better cable for unlocking E1 and e770 without battery it would be a great help .. I am sure everyone who unlocked this phone will love this idea... |
03-18-2006, 07:45 | #2 (permalink) |
No Life Poster Join Date: Jun 2004 Location: USA Age: 39
Member: 67927 Status: Offline Thanks Meter: 108 | The best way is to buy an original cable that will let you plug in an external charger to it... I use that cable for everyone phone that needs tp without using battary.... plug the charge to cable then from cable to phone, the charger is off because I have a switch for it, connect tp, then hit switch, remove tp, press search and it works 100% |
03-18-2006, 09:56 | #4 (permalink) | |
No Life Poster Join Date: Apr 2005 Age: 45
Member: 132856 Status: Offline Thanks Meter: 36 | Quote:
br kobby | |
03-18-2006, 18:12 | #5 (permalink) |
Member: 67927 Status: Offline Thanks Meter: 108 | it is a not a charger it is a cable....I use a reg charger to plug in the cable. http://www.originalwireless.com has those cables... http://www.originalwireless.com/98540.html Last edited by dest; 03-18-2006 at 18:32. |
ubl bug in unlocking rokr e1 | upgrader | Ultima Box Light | 12 | 02-28-2007 21:50 |
Unlocking ROKR E1 | D0cGSM | Motorola P2k | 3 | 08-21-2006 18:51 |
K750 Cable with no battery | ExTrEmE99 | SonyEricsson (USB-Smart) | 5 | 06-05-2006 01:33 |
I Installed New Skin On Rokr E1 and It Not Works!!! | ashkanemail | Motorola P2k | 0 | 05-28-2006 06:30 |
R220 with no battery sign?? | yousha | VLSI, Conexant, Skyworks and Old Models | 5 | 08-10-2004 13:26 |
