02-15-2008, 21:31 | #1 (permalink) |
Freak Poster Join Date: Jul 2006 Location: NW USA
Member: 304779 Status: Offline Thanks Meter: 5 | Unlocking RAZR V3 with smartclip (xe mobile) driver for this device. I plugged in the razr to the usb port on the laptop and presses the button on top of the smart clip, but nothing seemed to happen. Also, when unlocking, do i leave a simcard in the phone? Thank you in advance for your help. |
02-15-2008, 23:58 | #3 (permalink) |
Member: 304779 Status: Offline Thanks Meter: 5 | yes, I have the S-card inserted. The s/w version is DE.41.C3R_B There is also something that says V3(G8/9/18/19) behind the battery if that is related. |
The Following User Says Thank You to klaus06 For This Useful Post: |
02-16-2008, 00:52 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Murcia,Spain Age: 45
Member: 116918 Status: Offline Sonork: 100.1590386 Thanks Meter: 559 | Power on the handset while holding * and # and post back here what the bootloader screen shows you this will make it alot easier for all here to identify what unlock method you will need for your phone. But first of all you will the Smart-Adaptor,S-Card and Smart Clip updated to the latest versions and all installed with correct drivers on your PC. Heres the Smart-Adaptor and Smart-Clip update and install info http://www.smart-clip.com/index_adaptor.php Here can be found S-Card install info http://www.smart-clip.com/scard_start.php And The Latest Smart-Moto Here http://www.smart-clip.com/smartmoto.php |
02-16-2008, 04:05 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Cochabamba Age: 38
Member: 87396 Status: Offline Thanks Meter: 64 | so not connect your phone to pc usb port connect it to clip usb port but first do as mbcommunication says to see boot loader version if it is 07E0 or 0823 no computer is needed to unlock the phone if BL is 0826 you need to connect to your computer and make remove rsa procedure then unlock with the clip if it is 0828 0827 0829 you need to do prepare phone cycle if you have v3r youll need testpoint if bootloader is 0A52 or prepare cycle if it is 0A.30 or 0A.42 if you have V3re youll need smart testpoint adapter |
02-20-2008, 04:20 | #6 (permalink) |
Member: 304779 Status: Offline Thanks Meter: 5 | Here is what it shows at startup: ------------------------ Boot Loader SW Version: R374_G_0E.41.C 3R_B Battery OK OK to Program Connect USB Data Cable ------------------------ |
successfully unlock razr v3 bootloader R374-G-0E.41.C3R-B | ..::Mobile Smoker::.. | Ultima Box Light | 1 | 11-27-2010 23:34 |
Need help unlocking RAZR V3 | d3coy | Motorola P2k | 8 | 01-06-2007 02:45 |
Strange problem with unlocking Razr V3 | catcher | Motorola P2k | 10 | 07-28-2006 19:22 |
How to unlock Razr V3 8.26 using P2k Tool | enrikez | Motorola P2K (USB-Smart) | 5 | 04-19-2006 08:03 |
Urgent: help unlocking razr v3 | verysimple | Smart-Clip | 10 | 10-26-2005 12:00 |
