02-06-2008, 13:59 | #1 (permalink) |
Freak Poster Join Date: May 2003 Location: Ivory coast Age: 47
Member: 28749 Status: Offline Thanks Meter: 48 | V1050 AT command error V1050 user code but when I click on search button... SmartMoto 3.06 S-Card: ******XX Smart-Clip dongle, v 2.05, assigned Smart-Clip: ********* Europe, initializing... OK Clip serial: *********, version: 4.05, initializing... OK Searching for phone... found Motorola Phone (V1050), getting test interface... AT command error Searching for phone... found Motorola Phone (V1050), getting test interface... AT command error Searching for phone... found Motorola Phone (V1050), getting test interface... AT command error Searching for phone... found Motorola Phone (V1050), getting test interface... AT command error This error is possible during phone turning on, you may try <Search> once again please help sorry for my bad english |
02-06-2008, 14:05 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | You can try to perform the following: 1. power on the phone with any SIM 2. when it asks for user code, press MENU button 3. then it will ask for security password, enter 000000 and press OK (000000 - default security password. It might not be accepted, in case it was modified by user) 4. now you should be able to perform a Master reset & Master clear from the menu. If that will not help, than You should Full flash the handset using TP method. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-06-2008, 16:39 | #4 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Arnoldsp, That error appeared because of enabled User Code. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
v1050 and c975 at command error ??? | X-TRA | Smart-Clip | 6 | 06-03-2009 03:59 |
Allways AT Command error in smartmoto | UnlockerPT | Smart-Clip | 25 | 05-18-2006 07:57 |
smart moto,rsa,at command error. | hamzaa | Smart-Clip | 2 | 08-31-2005 09:52 |
AT commande error on versin 2.15 | HEADMASTER | Smart-Clip | 4 | 07-19-2005 14:06 |
