05-21-2007, 10:38 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 53
Member: 151195 Status: Offline Thanks Meter: 7 | v235 in bootmode after unlocking |
05-21-2007, 10:57 | #4 (permalink) |
No Life Poster Join Date: Feb 2005 Location: P A K I S T A N
Member: 113943 Status: Offline Thanks Meter: 73 | first try to unlock again if problem still then unlock via test point but m sure when u unlock again via patch smart moto all ur backup write again and set going on in last u can try via flash its only solution |
05-21-2007, 11:38 | #5 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ telenet01, If there was any mistakes made during unlock process, and the handset is in boot mode, then phone has to be flashed with the same firmware version that it originally had or higher one. If during flash procedure some error appears, please post log file here. Don't forget to hide serial number. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-11-2007, 18:26 | #7 (permalink) | |
No Life Poster Join Date: Jun 2001 Location: www.microera.si
Member: 4923 Status: Offline Thanks Meter: 74 | Quote:
-read system -prepare again....and all is OK ... V235 is unlocked! LOG: SmartMoto 2.23 S-Card: 1304***** Smart-Clip dongle, v 1.24, assigned Smart-Clip: 7798***** Europe, initializing... OK Clip serial: 7798*****, version: 3.17, initializing... OK Searching for phone... found Motorola Phone (V235), getting test interface... OK Model V235 Firmware R3512_G_0A.30.6CR Operation log saved to "C:\Program Files\GsmServer\SmartMoto\SmartMoto log 11-06-2007_v235unlock.txt" Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... 8.E0 Boot prepare... failed Reading phone boot version... io timeout Searching for phone... found Motorola Phone (V235), getting test interface... OK Model V235 Firmware R3512_G_0A.30.6CR Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... 8.E0 Sending boot... OK Performing backup to temporary file Stored temporary backup to C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F909C64A00FB0C0E.bk_ Backup OK Erasing flash memory error 80 Searching for phone... no phone found Searching for phone... found Motorola Phone (V235), getting test interface... OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... 8.E0 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Flash Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 8.E0 Boot prepare... failed Operation log saved to "C:\Program Files\GsmServer\SmartMoto\SmartMoto log 11-06-2007_V235_BootPrepare_Failed.txt" Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 8.E0 Sending boot... OK Erasing flash memory OK Sending firmware OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... none, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7v,K1 Hardware IMEI: 3564810018***** Security area saved to "PDS for S Blank Neptune LTE2 3564810018*****.mbk" Performing restore from temparary backup file C:\Program Files\GsmServer\SmartMoto\temporary backup\bkp_F909C64A00FB0C0E.bk_ Restore OK Unlocking phone... OK | |
help in v3x after unlock no display | sofiame2006 | Motorola Hardware Repair | 15 | 08-15-2008 14:49 |
help in v3x after unlock no display | sofiame2006 | Motorola P2k | 1 | 01-06-2007 22:11 |
Only Spice In D500 After Unlocking | cellco_mann | Samsung Hardware Repair | 3 | 08-08-2006 18:59 |
Problem In V360 After Unlock !!!! | gsmsalik | Smart-Clip | 2 | 01-05-2006 18:26 |
Lg 8330 Battery Discharge In 40hours After Unlock!!! | gsm_unlock | LG | 3 | 07-27-2005 11:17 |
