04-20-2006, 05:29 | #4 (permalink) |
Freak Poster Join Date: May 2005
Member: 143322 Status: Offline Thanks Meter: 35 | I have the same error with v3.........when i try to full flash the software says ''Incomplete chip identity, flas or backup writ unavailable''.....i try to repair pds but the same error.. what can i do now....Plz help. BR. Faisal. Opal Mobiles. |
04-20-2006, 08:58 | #5 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | Hello faisi, Incomplete chip identity means that flash chip can't be read properly. Try to reconnect the phone! if it will not help than try to reheat it with hot air, it may help! Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-20-2006, 09:08 | #6 (permalink) |
Crazy Poster Join Date: Dec 2004 Location: UK Age: 44
Member: 102029 Status: Offline Thanks Meter: 0 | just a little quick guess but i hear you have to flash Pds repair then you have to full flash the bootloader and mosnter pack. motox.us has the files you need |
04-20-2006, 10:54 | #8 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ faisi, Please tell us what had happened to phone! What was the original problem? Can You post log file here? Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-20-2006, 11:16 | #9 (permalink) |
Freak Poster Join Date: Sep 2002 Location: Palestine/Germany Age: 53
Member: 15593 Status: Offline Thanks Meter: 19 | L7 always in flash mode Hello, i have a L7 always in flash mode. This problem becames after i want to change languagepaket. I have tested different flashfiles. I have repair PDS with Fullflash. please help. noko |
04-20-2006, 11:48 | #10 (permalink) |
Member: 143322 Status: Offline Thanks Meter: 35 | I recieve fone in hang and restart pb. i flash it with these files... 1.R374_G_0E[1].42.0CR_lp0031_full_flash 2.R374_G_0E[1].42.0CR_lp0031_reflash 3.R374_G_0E[1].42.0CR_lp0031_SE8604AXXG10AB_flash_flex and after this set goes in flash mode automatically when i press the pwr button...... and after this when i try to flash or repair pds the massage shows like this.. SmartMoto 1.19 Clip serial: xxxxxxxx, version: 2.24, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 35xxxxxxxxxxxxxxx Incomplete chip identification, restore & write functions unavailable Plz Guide me....What can i do now.. Thanks BR. Faisal. Opal Mobiles. |
04-20-2006, 13:44 | #11 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | Hello faisi, Flash chip is damaged. Try reheat it with hot air, it may help. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-26-2006, 07:26 | #12 (permalink) |
Junior Member Join Date: Apr 2006
Member: 266574 Status: Offline Thanks Meter: 0 | "boot loader 08.26 sw version: r374_g 0e.420.ar_b" after flash i have dead v3, and I tried to flahs it with test point. after that the screen show Boot Loader 08.26 SW. Version: r374_g 0e.420.ar_b Battery OK OK to Program Connect usb data cable I've trying to flash it again with test point, but it doesn't work, smart clip says " phone not found!" I've tried many times, but the software still "phone not found" give me some solution pls |
04-26-2006, 09:20 | #13 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | Hello vanbasten, Why You have done TP for this phone Boot Loader 08.26? It can be done in such way: Unlocking V3 (boot ver.8.26) You need to use SmartMoto to unlock these models. 1. Power on the phone. 2. Connect it to PC via smart-clip, detect your phone in SmartMoto. 3. Go to Unlock bookmark, pick your model, press "Remove RSA" button. 4. Phone goes into boot mode. 5. Part of phone firmware is reflashed. 6. The phone powers on and is ready to be unlocked by Smart-Clip using simple "press one button" method (press Unlock button on Smart-Clip). Now You can try to connect the phone to PC, and check if Windows will see the phone. IF it can be seen by PC than try to connect it using Smart-Moto after that make Repair PDS and Full Flash the phone. Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
04-26-2006, 18:52 | #14 (permalink) | |
Member: 266574 Status: Offline Thanks Meter: 0 | Quote:
I've just tried it this this is the operation log SmartMoto 1.19 Clip serial: 4xxxxxxxx, version: 2.24, initializing... OK Searching for phone... no phone found Searching for phone... no phone found the phone is on, phone connection is smart clip usb port I use Usb cable from phone conecting to smart clip's Usb tell me more information to get my phone alive back Last edited by vanbasten; 04-28-2006 at 17:17. | |
04-26-2006, 20:03 | #15 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 41
Member: 84130 Status: Offline Thanks Meter: 8 | HI, when you have the following error with smartmoto: SmartMoto 1.19 Clip serial: xxxxxxxx, version: 2.24, initializing... OK Searching for phone... found S Flash Neptune LTE, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 7.E0 Reading flash id... Intel-0x0089 Phone group: V30x,V40x,V50x,V52x,V60x Hardware IMEI: 35xxxxxxxxxxxxxxx Incomplete chip identification, restore & write functions unavailable Just flash the phone with PST, after that the phone will work again and you can use smartmoto again. I did that with a V3 with the same problem after flash several times with smartmoto and work fine now. I don't know why this happen some times with smartmoto. |
v3 always in boot mode w/o display | kades | Smart-Clip | 6 | 06-25-2007 08:26 |
v975 always in flash mode | vbfather | Motorola P2K (USB-Smart) | 8 | 07-29-2006 15:30 |
v551 no power...always in flash mode | dest | Motorola P2k | 6 | 06-21-2006 20:35 |
V220 always in flash mode !!! | GSM SNIPER | Motorola P2k | 3 | 09-15-2005 02:06 |
mss4box always in flash mode | hema | Motorola P2k | 3 | 02-07-2005 13:01 |
