01-06-2008, 02:02 | #1 (permalink) |
No Life Poster Join Date: Jun 2003 Location: somewhere Age: 40
Member: 31028 Status: Offline Thanks Meter: 56 | v3 display i've switched a v3 pcb for a v3i carcase. the display doesn't work. what can i do? do i have to flash? what version? v3 pcb works ok. the v3i flex and display is ok to. regards |
02-04-2008, 08:32 | #5 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ MAGYVER, Please explain in more details what is wrong with the phone. What problem the phone originally had? What has been done to it? Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-04-2008, 11:51 | #6 (permalink) | |
Freak Poster Join Date: Jan 2007 Location: tunisia
Member: 430847 Status: Offline Thanks Meter: 19 | Quote:
HELLO ,I CAN RECIVE CALL AND LISTEN MUSIC ,THE PHONE WORK GOODLY ONLY THE DISPLAY NOT WORK ,I CHANGE THE ECRAN AND NOTHING ,HAVE ANY SOLUTION PLEASE SHORT CIRCUIT OR ANY OTHER SOLUTION ,THANKS FREIND [email protected] | |
02-04-2008, 12:01 | #7 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ MAGYVER, Try to perform Repair PDS procedure (for the same platform like the handset has!) and after that Full Flash the phone with higher firmware version. In case if the problem will be the same, most probably that the handset has some hardware malfunction. P.S. Repair PDS and flashing procedure should be performed for the same platform like the phone has. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
02-04-2008, 12:15 | #8 (permalink) | |
thinks freind but there is the same problem I do this step and nothing ,have you another solution please | |
v3 display problem.Some few seconds display getting off | sharaz191 | Motorola Hardware Repair | 0 | 10-31-2007 12:45 |
V3 Display | ryaz1993. | Motorola Hardware Repair | 3 | 05-31-2006 07:12 |
V3 display problem | pinmobil | Smart-Clip | 2 | 03-23-2006 12:42 |
Motorola V3 Display white (no display) | garibaldi1970 | Motorola Hardware Repair | 1 | 12-09-2005 13:25 |
V3 Display Shaking | stboon | Motorola P2k | 3 | 07-19-2005 06:29 |
