02-21-2008, 19:08 | #1 (permalink) |
Freak Poster Join Date: Nov 2007
Member: 639554 Status: Offline Thanks Meter: 6 | V3 Key Pad Problem can anybody help. i have v3 with a keypad problem. at first it was both screen light and keypad. i have replace a new chord,the screen light ok but some of the keypads not working. have tried all i can do but still. someone help please. |
06-11-2008, 12:36 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ girumm, In most cases problems with the keypad shows that the phone has hardware malfunction, but to be sure you can try to perfrorm Repair PDS procedure and after that Full Flash the set with higher firmware version. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-11-2008, 14:25 | #5 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Dominica, West Indies Age: 63
Member: 88701 Status: Offline Thanks Meter: 381 | If the entire keypad (all keys) are not working...then first perform full flashing. Should the problem remain after fullflash, then reflow the controller. Good Lucke ;smokin |
***v3 Key Pad Not Working Solution**>>> | mobilecraker | Motorola Hardware Repair | 7 | 11-25-2011 09:02 |
V3 key pad flex problem | nost | Motorola Hardware Repair | 0 | 08-21-2007 21:42 |
v3 key pad | WIDE | Motorola Hardware Repair | 11 | 07-14-2007 09:48 |
v3 key pad do not work after flash how to resolve ? | leroi | Smart-Clip | 10 | 11-16-2006 20:17 |
Razr V3 Key Pad | tank23 | Motorola Hardware Repair | 0 | 08-01-2006 13:17 |
