11-29-2005, 15:57 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: bucharest
Member: 9843 Status: Offline Thanks Meter: 2 | v360 boot 08.70 cannot be unlocked via tp, error 9B i have a moto v360, i connected tp, i backed it up successfully but when i press unlock via tp i get error 9B i have never seen this error until now though i ve unlocked about 3 pcs last week thanks for you help sc team mihai |
11-30-2005, 13:58 | #3 (permalink) | |
Freak Poster Join Date: Jun 2003
Member: 30402 Status: Offline Sonork: 100.108200 Thanks Meter: 8 | Quote:
PS. trebuia sa faci un search, eu am mai zis de errorile astea, ptr ca daca stai si te ghindesti doar e ARM (k si la siemens). i wait the result here | |
12-01-2005, 18:55 | #7 (permalink) |
Junior Member Join Date: Jun 2005 Location: London Age: 51
Member: 153664 Status: Offline Thanks Meter: 0 | question ?? flashing v360 possible with TP or without smart clip was unable to unlock that fone i done with mss4 but smart kill the fone already before using mss4 ( i get always errors any tested solution if any1 knows otherwise wait for our experiements |
12-01-2005, 20:39 | #8 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Satcom Bangalore INDIA Age: 53
Member: 17098 Status: Offline Thanks Meter: 51 | @SC Team plz Update Smartmoto..... Clip serial: xxxxxxxxx, version: 2.18, initializing... OK Searching for phone... found SE Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel-28F256L18B Phone group: V360 Hardware IMEI: 356393000xxxxxx Security area saved to "SE Blank Neptune LTE2 356393000xxxxxx.pds" Unlocking phone... error 9B |
12-02-2005, 08:14 | #9 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Timeless zone! Age: 35
Member: 152244 Status: Offline Sonork: 100.1591179 Thanks Meter: 162 | SC Team i also want to know that how to solve this problem..............Good Luck.......................Ok Br Muneeb Akhtar Raza |
12-17-2005, 01:40 | #10 (permalink) |
Freak Poster Join Date: Dec 2005 Location: new york
Member: 208709 Status: Offline Thanks Meter: 31 | ////////////////////////////////////////////////////////////////////////////// Last edited by GSM_Support; 12-19-2005 at 16:15. Reason: Message deleted. Contained serial number |
12-23-2005, 00:01 | #13 (permalink) |
Member: 208709 Status: Offline Thanks Meter: 31 | Clip serial: .............., version: 2.17 - you need to update Smart-Clip Clip serial: ..............., version: 2.18 Clip serial:XXXXXXXXX, version: 2.18 SmartMoto license saved Clip serial: XXXXXXXXX, version: 2.18, initializing... OK Searching for phone... found Motorola Phone (V360v), getting test interface... OK Model V360v Firmware R4513_G_08.B7.56R_A Reading info OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... 8.A0 Sending boot... load error Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Sending boot... failed Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Sending boot... failed Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Searching for phone... found Motorola Phone (V360v), getting test interface... OK Model V360v Firmware R4513_G_08.B7.56R_A Reading info OK Switching to flash mode... OK [S Flash Neptune LTE2] Reading phone boot version... 8.A0 Sending boot... load error Warning: Phone may need "Remove RSA" procedure to get unlocked or flashed, check model list at "Unlock" tab if flash mode fails to start Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel-28F256L18B Phone group: V360 Hardware IMEI: 35687xxxxxxxxxxxxxxxx Security area saved to "S Blank Neptune LTE2 356871000411870.pds" "S Blank Neptune LTE2 3568xxxxxxxxxxxxx.smb" saved, 32 Mb Unlocking phone... OK Last edited by trycktill; 12-24-2005 at 03:37. |
12-23-2005, 17:38 | #14 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Romania Brasov Age: 46
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | hi i have a moto v360, i connected tp, i backed it up successfully but when i press unlock via tp i get error A0 Please help . I want reflash . i dont have flash file. |
12-23-2005, 19:00 | #15 (permalink) |
No Life Poster Join Date: Aug 2004 Age: 47
Member: 76522 Status: Offline Thanks Meter: 30 | a0 code mean that u sold wire 2 tp and phone all time think that it have empty flash. use needle. and all be ok. by the way when u disolder wire phone will power up. |
L7 (2 pcs.) ver. R4517_G_08.C4.1ER CANNOT BE UNLOCK VIA SMARTCLIP??? | mymiela0419 | Smart-Clip | 10 | 06-21-2009 20:52 |
V3 boot loader 08.26 can be unlock By UBL? | denard | Ultima Box Light | 7 | 11-27-2007 18:27 |
When will be support V360 boot 08.A2 ? | SVH | Smart-Clip | 2 | 04-11-2007 19:42 |
New Boot Loader to V360. 09.02. Itīs posible unlock without Tp? | Grupo MovilFree | Smart-Clip | 1 | 01-26-2007 13:16 |
Can you please doublecheck V360 Boot 08.A0 non TP process????? | eskerra | Smart-Clip | 1 | 01-05-2007 06:04 |
