01-13-2007, 21:11 | #1 (permalink) |
No Life Poster Join Date: Aug 2002 Location: Croatia Age: 48
Member: 14602 Status: Offline Thanks Meter: 18 | v360v no sound on speaker after flashing? here is log Reading phone boot version... 3.00 Reading flash id... 0x0090-0x0090 Phone group: V235,V360,V360v,V3i,V3r,L7,L7v |
01-15-2007, 09:23 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ mmanduri, Such, Reading flash id... 0x0090-0x0090, error usually appears when flash chip can't be read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. If TP wasn't made correctly, then you can try to flash this handset with backup once again. After flashing with backup you have to Restore Security Area. Manual can be found here: http://www.smart-clip.com/sm_manual.php Best Regards Smart-clip team www.smart-clip.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
v360v no sound on speaker | mmanduri | Smart-Clip | 1 | 12-30-2006 10:29 |
Mpx220 no sound on speaker (resiver) | Porter | Motorola Hardware Repair | 4 | 04-14-2006 18:49 |
sl45 no sound on speaker | Lutfe | Siemens Hardware Repair Area | 3 | 12-07-2004 12:04 |
mc 60 no sound on speaker??? | mmanduri | Siemens Hardware Repair Area | 5 | 09-21-2004 21:01 |
C35, no sound on speaker after unlock | IrdetoMaster | x1x to x45/x50 | 21 | 11-20-2002 18:07 |
