10-13-2007, 09:45 | #1 (permalink) |
Insane Poster Join Date: Sep 2006 Location: Philippines
Member: 346449 Status: Offline Thanks Meter: 5 | V3i 0A.30 R479_G_08.B5.86R Bootmode only...!!! I already done it by full flashing, repair pds, prepare phone but still no luck......, Can you help me how to resolve this problem using SmartClip w/ S-card......, Can you tell to me all the one by one procedure in flashing....? Many Thanks in Advance........, |
10-13-2007, 09:53 | #2 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Viga_10, Please tell us what flash files you have used to flash this handset. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
10-13-2007, 09:56 | #3 (permalink) |
Member: 346449 Status: Offline Thanks Meter: 5 | @ Sir Mr. Tinkertrain I already use this sir V3i_R479_G_08.B4.86R_A_lp0030_full_flash.mfw and this V3i_R479_G_08.B5.10R_lp002E_full_flash.mfw but still no luck....., Can you help me Sir to my problem....., TIA |
10-14-2007, 02:10 | #7 (permalink) |
Member: 346449 Status: Offline Thanks Meter: 5 | Sorry for reviving this thread because my problem is still no luck, is there anyone can give me this file for smartclip or rsd lite......, V3i 0A.30 R479_G_08.B5.86R Thanks in Advance...., |
10-14-2007, 04:33 | #8 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: NA & CN
Member: 99013 Status: Offline Thanks Meter: 52 | Quote:
R479_G_08.B5.76R...I use other moto tool do pds repair,it uses old version as template,so after that b5.76R become newer one ,by this way 76R can fix your v3i or V3t... Good Luck Gsmdoctorca | |
10-15-2007, 07:58 | #10 (permalink) | |
No Life Poster Join Date: Mar 2006 Location: Inside MTK Age: 38
Member: 248182 Status: Offline Thanks Meter: 786 | Quote:
Can you tell Me Which Tool can Solve The Problem. and how V3i will Become V3t Plz Need Explanation. WBR Bluffmaster | |
11-13-2007, 15:57 | #11 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 396605 Status: Offline Thanks Meter: 8 | Hello; I have two V3i from roger dead, with the same flash V3i 0A.30 R479_G_08.B5.86R , I did unlock with smart-clip, i didn't now what happen with this flash in particular. I tried later repair with smart-clip, i flashed with all b5.xxR.pcf files in scout, and nothig, i did prepare phone, and flash again, nothing. I'll try today to restore IMEI to see what happens???, I think this phones from rogers with this flash are not supported yet in smart-clip for unlock. What does smart-clip support think about this??? Thanks to all people that share his experience here. |
11-13-2007, 16:25 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ bobxxx, Please explain in more details what had happened with the handset. Show log file form unlocking procedure. Same firmware vesion like the handset originally had can be found at boot-loader.com Try to flash the phone with it. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
11-13-2007, 16:57 | #13 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Central Europe Age: 39
Member: 239548 Status: Offline Thanks Meter: 2,781 | Viga_10, In order to revive phone with fw version R479_G_08.B5.XXX you have to flash it with the same or higher firmware version. AFAIK B5.XXX version is sticky, so it can not be downgraded. |
V3i R479_G_08.B5.86R LP0024 Full Flash, Please help Mod. | Phantom | Smart-Clip | 13 | 01-20-2010 08:26 |
V3i boot lader@R479_G_08.B5.86R | ROSE@DVD | Motorola P2k | 7 | 03-06-2008 22:42 |
V3i 0A.30 R479_G_08.B5.86R Flash File in RSD LITE badly needed..., | Viga_10 | Smart-Unlocker | 2 | 10-13-2007 12:56 |
How write lang to V3i 0A.30 (white out TP) | GsmLiberty | Smart-Clip | 9 | 02-04-2007 14:21 |
Is V3i 0A.30.SW Version R479_G_08.B4.34R Supported? | James-R | Smart-Clip | 0 | 01-11-2006 15:36 |
