06-05-2008, 00:05 | #1 (permalink) |
No Life Poster Join Date: Apr 2002 Location: The Green Mile
Member: 11325 Status: Offline Thanks Meter: 266 | V3i D&G stuck in bootloader .... after searched all threads and tried everything possible as discussed repair PDS, FULL flash the set is stil lstuck in bootloader. Tried both with prepare and with TP. version is R479_G_08.B4.34R. Flashed it with V3i_R479_G_08.B4.85R_lp0039_full_flash and still the same. Used a ******* flash of the exact version R479_G_08.B4.34R and no change what else can i do pls? thanks |
06-05-2008, 03:08 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Vietnam Age: 50
Member: 149256 Status: Offline Thanks Meter: 285 | Here's my way for this problem : 1. repair PDS (make TP ofcouse) 2. flash phone with R479_G_08.B4.8BR_lp0021_full_flash.mfw 3. patch Imei 4. restore Imei That's all I hope this procedure may help you. |
06-05-2008, 04:38 | #3 (permalink) |
Insane Poster Join Date: Aug 2007 Location: jamaica
Member: 563980 Status: Offline Thanks Meter: 1 | Perfect File That U Need SEARCH AND DOWNLOAD THIS FILE AND UR GOOD AND READY AGAIN R479_G_08.B5.76R_PDS006_LP0033_DRM0101_VSTUK_ENGLI SH206_JPJAVA_G_08_V3i_03_00R_GSPSLQAT678GH1A8_1FF. sbf |
06-05-2008, 07:41 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ Burnt Cobba, Please tell us what problem the phone originally had. Try to Full Flash the phone with the highest available firmware version for this platform, R479_G_08.B5.86R. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
06-05-2008, 07:55 | #5 (permalink) |
No Life Poster Join Date: Jan 2003 Location: bestncheap Age: 43
Member: 19785 Status: Offline Thanks Meter: 1,242 | try use this file R479_G_08.B5.76R_PDS006_LP0003_DRM0101_VSTAM_SPANI SH206BR_PORTUGUESE206US_ENGLISH206_JPJAVA_G_08_V3i _01_01_04R_GSPSLQA1DGMSTVZLA17A_1FF[Movistar Venezuela UI ***** & Gabanna].pcf flashing with scout.. Your phone will life again in ***** gabana.. or at least use firmware with version R479_G_08.B5.***R use B5 Full flash firmware BR BNC |
06-06-2008, 07:53 | #12 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Burnt Cobba, More likely that the phone was flasher with wrong platform flash file. Due to this reason it stays in boot mode. You can try to perform the following: 1. Make Repair PDS for R479 platform 2. Flash the phone with R479 firmware version (the highest one, R479_G_08.B5.86R) 3. Perform IMEI patch. 4. Restore ORIGINAL IMEI using SmartMoto Restore IMEI option. NOTE: Phone cable should not be disconnected during the whole process until the last step is performed. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
The Following User Says Thank You to Mr.Tinkertrain For This Useful Post: |
06-06-2008, 13:27 | #13 (permalink) |
Member: 11325 Status: Offline Thanks Meter: 266 | @MrTinkertrain First of all thanks a lot for your continous help. Secondly in one of your replies in similar threads you wrote that the flash chip might have to be replaced. Is this the case? or was it in other times? The last step of the imei if imei is still correct (as i tried to unlock and it seems to be ok) is this always needed anyway? Thanks |
06-06-2008, 13:43 | #14 (permalink) |
Member: 229997 Status: Offline Thanks Meter: 636 | @ Burnt Cobba, Try to perform procedures mentioned in this post. Restore IMEI procedure has to be performed. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com Last edited by Mr.Tinkertrain; 06-06-2008 at 13:50. |
motorola v3i stuck in bootloader | RUBEL SINGH | Smart-Clip | 8 | 09-14-2016 07:53 |
v3i stuck in bootloader! | accepttheownage | GOT Motorola | 0 | 08-18-2008 22:23 |
v3i D&G stuck in bootloader mode help needed | amit_varietymob | Motorola P2k | 3 | 08-08-2008 17:05 |
V3i stuck in Bootload mode | helplease | Motorola P2k | 10 | 06-27-2007 04:28 |
Please help , my V3i stuck in bootloader !!!! | nova75c | Smart-Clip | 9 | 06-13-2007 22:50 |
