Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > GSMServer Products > Smart-Clip
Old 06-02-2006, 21:13   #1 (permalink)
Member: 8843
V3i DEAD SOLUTION HERE!!!
am looking for a solution:
i tried to unlock this motorola V3i using TP and it just stopped on the way,
as per bottom logged file showing "Unlocking phone... error A0" now phone is DEAD
cant even get to boot loader.
SmartMoto 1.20
Clip serial: xxxxxxxx, version: 2.25, initializing... OK
Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found
Switching to flash mode... OK
Reading phone boot version... 3.00
Reading flash id... 0x0090-0x0090
Phone group: V360,V360v,V3i,L7,L7v
Hardware IMEI: AA070BF82F0D6F3
"S Blank Neptune LTE2 AA070BF82F0D6F3.smb" saved, 64 Mb
Operation log saved to "D:\Program Files\GsmServer\SmartMoto\v3i.txt"
here i now tried to flash the boot file "v3i_boot_A.3.0" but failed to flash!!!
SmartMoto 1.20
Clip serial: xxxxxxxxx, version: 2.25, initializing... OK
Incomplete chip identification, restore & write functions unavailable
any helping solution ???? thanx in advance.
data
Old 06-02-2006, 22:50   #2 (permalink)
fingusio's Avatar
Member: 16927
Sonork: 100.1592866
Hmm... what happen when you try unlock again?
br,
fingusio
Old 06-03-2006, 00:38   #3 (permalink)
Member: 142233
you can use UP-128 &256 &1024 erase fash IC
try again unlock
look imei,
if no=your phone imei
the flash IC bad
Old 06-03-2006, 04:10   #4 (permalink)
Member: 57549
Check instruction my friend ,,,...
On that case ... Hardware IMEI is not intact cause of the wrong testpoint or testpoint not detach ...
JammerOne
Old 06-03-2006, 09:04   #5 (permalink)
Mr.Tinkertrain's Avatar
Member: 229997
Hello datalife2000,
means that flash memory chip is not read properly. There are two main reasons for that:
1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair.
Connection between the chip and the processor may be improved by the hot air.
2. Testpoint procedure was not performed properly -- just to make sure please, repeat the pt procedure.
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
www.smart-unlocker.com
Old 06-03-2006, 09:38   #6 (permalink)
Member: 8843
@ Mr
problem solved.tp. thanx.
Old 07-10-2006, 06:08   #7 (permalink)
FMC_GSM's Avatar
Member: 306786
Sonork: 100.1596805
v3i dead
mr. zulea can you give me a flashfile R47A, because
theres no available in support area..
Old 07-10-2006, 08:37   #8 (permalink)
Member: 229997
@ brobigbro,
You can find Full Flash for V3i, R47A_G_08.D8.35R on boot-loader.com
Best Regards
Smart-clip team
www.smart-clip.com
www.GsmServer.com
www.boot-loader.com
Old 07-10-2006, 10:00   #9 (permalink)
Member: 198756
Originally Posted by datalife2000
@ Mr
how did u solved your problem please? please tell me the details
greeni222000@yahoo.com
thanks in advance for ur replay
Old 09-02-2006, 15:03   #10 (permalink)
Member: 97588
please tell how you revive fone,hardware or software?
Old 09-13-2006, 13:58   #11 (permalink)
Member: 13100
Pls help e repair my phone
Originally Posted by datalife2000 View Post
@ Mr
HElla Datalife. pls help me . how do you repair your phone. I lost V360 and E770v by the way.
ETS2208 dead solution here mohit_kripalu01 Various CDMA/TDMA Cell Phones 2 12-10-2009 13:50
Alcatel S211 Dead Solution here! Nadjombe Alcatel TCL Phones and New Models 4 10-17-2009 00:24
some nokia dead solution here..... rumenshom Nokia Hardware & Hardware-Repair Area 1 01-06-2009 15:18
v903sh dead solution here (for cruiser user) reignsmart Cruiser Suite 25 01-20-2007 17:16
A3x Dead or Wrong Soft... SOLUTION HERE by Smoother smoother x1x to x45/x50 4 11-27-2001 11:56
Page generated in 0.46675 seconds with 11 queries
