12-20-2009, 07:29 | #1 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Bangladesh Age: 42
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | V3i Shows Critical Error 80 40; Firstly i have try to flash the phone with Scout R479_G_08.B4.89R_PDS005_LP0055_DRM0101_VSTUK_ENGLI SH206_JPJAVA_G_08_V3i_03_00_15R_GSPSLQAT678RS146_1 FF_Z_Generic_Australia.pcf with this file (phone fw version is same also). flashing is ok. but phone is in the bootloader mode. Then i have try to Repair Pds & flash Of this Phone with Smart moto. But all procudure was fail. It shows Critical Erro 80 40. Help me to repair this phone. Here is the Log: Searching for phone... found S Flash Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... A.52 Boot prepare... failed |
The Following User Says Thank You to sanjoychy For This Useful Post: |
12-21-2009, 05:06 | #6 (permalink) |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Just Now I am successfully Repair of this phone. Flash was also completed successfully. But the phone is still in bootloader mode. Here is the log: Searching for phone... no phone found Searching for phone... found S Blank Neptune LTE2, getting test interface... interface not found Switching to flash mode... OK Reading phone boot version... 3.00 Reading flash id... Intel - 28F256L18B Reading flash id/2... Intel - 28F128L18T, OK Phone group: V235,V360,V360v,V3i,V3r,L7,L7e,L7v,L71,L72,L9,K1,U 3,W5,W490,W510,Z3 Hardware IMEI: 354514017848443 IMEI OTP status: locked Security area saved to "PDS for S Blank Neptune LTE2 354514017848443 (2).mbk" Writing flash section 2 of 2... 100% (24.4 Kb/sec) Restarting phone... OK Searching for phone... found S Blank Neptune LTE2 Switching to flash mode... OK IMEI OTP status: locked Performing PDS repair... OK Writing flash section 1 of 1... 100% (14.6 Kb/sec) Please write a corresponding Full_flash file to phone to complete repair Writing section1 done Turning phone off... OK Flash completed! When i received the phone then phone boot version was 0A.52 & Sw version was : R479_G_08.B4.89R After repair the phone boot ver is 0A.30 & Sw ver is : R479_G_08.B4.34R I have tried to flash 3 times with this firmware 1. V3i_R479_G_08.B4.85R_lp0039_full_flash.mfw 2. R479_G_08.B4.89R_PDS005_LP0055_DRM0101_VSTUK_ENGLI SH206_ JPJAVA_G_08_V3i_03_00_15R_GSPSLQAT678RS146_1FF_Z_G eneric_Australia.pcf 3. V3i_R479_G_08[1].B4.34R_lp0039_full_flash.smf Suggest me what should i do now |
12-21-2009, 06:24 | #7 (permalink) |
No Life Poster Join Date: Jun 2006 Location: Bangladesh
Member: 303373 Status: Offline Sonork: 100.1584377 Thanks Meter: 1,241 | Code: Just Now I am successfully Repair of this phone. Code: Suggest me what should i do now. |
12-21-2009, 08:31 | #8 (permalink) |
Product Supporter Join Date: Feb 2005 Location: GSMserver Team
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ sanjoychy, What information is now specified at the screen of the phone? Best Regards GSMServer team |
12-21-2009, 08:34 | #9 (permalink) |
No Life Poster Join Date: Apr 2008 Location: PhP Age: 42
Member: 757799 Status: Offline Thanks Meter: 782 | Flash again in scout flasher with this firmware r479_g_08.b5.86r_lp0003_gspv3ihdst01na199_1ff |
The Following User Says Thank You to trio1 For This Useful Post: |
12-21-2009, 16:30 | #10 (permalink) | |
Member: 180833 Status: Offline Sonork: 100.1578281 Thanks Meter: 217 | Quote:
0A.30. SW Version: R479_G_08.B4.34R | |
12-21-2009, 16:54 | #11 (permalink) |
Member: 121052 Status: Offline Sonork: 100.107126 Thanks Meter: 80,766 | @ sanjoychy, Do you know what initially had happened to this set? What firmware version it originally had? More likely that it was flashed with wrong platform firmware version. Best Regards GSMServer team |
The Following User Says Thank You to GSM_Support For This Useful Post: |
12-21-2009, 20:13 | #12 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Jr Telecom™
Member: 409725 Status: Offline Sonork: 100.1581478 Thanks Meter: 797 | Did u perform any once higher platform ? if that u hv to flash always higher. Try to repair pds by another platform then full flash with MFW if not pcf also. post result.. |
The Following User Says Thank You to Jr Telecom For This Useful Post: |
12-22-2009, 07:36 | #13 (permalink) | |
I am happy. At Last My phone is ok now. I have flashed the phone with this file R479_G_08.B5.86R__GSPV3IRGRS01NA19D_1FF_Rogers_Wir eless_locked.pcf via Scout. And after flash Just unlocked the phone via smart moto. | |
Critical error 80 40 on V3i | Romu | Motorola P2k | 6 | 05-15-2007 21:34 |
critical error 80 40 | ckkckk | Smart-Clip | 19 | 07-13-2006 10:08 |
!!!!!!!L6 unlocking!!!!!!! CRITICAL ERROR 80 40 | GAZZUZZ | Smart-Clip | 1 | 04-28-2006 14:16 |
PDS repair for V3i is not working - Critical Error 80 40 | armkbdotcom | Smart-Clip | 5 | 04-02-2006 20:54 |
critical error 80/40 while unlocking/flashing | kekudo2 | Smart-Clip | 1 | 03-31-2006 07:54 |
