01-16-2008, 23:42 | #1 (permalink) |
Junior Member Join Date: Mar 2005 Age: 70
Member: 130225 Status: Offline Thanks Meter: 0 | V3r Band Selection - Auto? Model V3r Operation band GSM 900/1800 Firmware R4515_G_08.BD.44R Flex version SE5573AXXB3093 - 1.0.2.3.2.2.0.2Q.0.0.18 Language pack 0539 I would like to use a pair of these phones on a trip to the USA, so GSM 850/1900 would be preferable. I think this phone is Quad Band, but when I use Update Band it resets. Is there anything I can do to make the band selection automatic? If not, how can I make it stay on GSM 850/1900 for my trip. |
01-17-2008, 03:06 | #2 (permalink) |
No Life Poster Join Date: May 2005 Location: Vietnam Age: 50
Member: 149256 Status: Offline Thanks Meter: 285 | V3r is Quad Band, you can change it to work on auto or 850/1900 band first, select menu-->settings-->Network-->Network setup-->Band-->auto(or 850/1900)-->finally remember seclect "done". That's all |
01-21-2008, 10:11 | #3 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: ETIVAC
Member: 584832 Status: Offline Sonork: 100.1601217 Thanks Meter: 35 | i try to unlock v3r with boot a52 via tp but cannot unlock here is the log... Quote:
br.. | |
01-21-2008, 10:21 | #4 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 229997 Status: Offline Thanks Meter: 636 | @ rannie, Incomplete chip identification means that flash memory chip is not read properly. There are two main reasons for that: 1. The flash memory chip is damaged or doesn't communicate with the processor. In this case the phone needs hardware repair. Connection between the chip and the PCB may be improved by the hot air. 2. Testpoint procedure was not performed properly -- just to make sure please, repeat the tp procedure. Best Regards Smart-clip team www.smart-clip.com www.scoutdongle.com www.GsmServer.com www.boot-loader.com www.smart-unlocker.com |
01-21-2008, 10:29 | #5 (permalink) | |
Member: 584832 Status: Offline Sonork: 100.1601217 Thanks Meter: 35 | Quote:
br | |
c200 band selection problem | 3gtech | Motorola Old Legacy (EMMI) | 1 | 05-24-2006 17:36 |
[K608i] Enable Band Selection Menu ? | speck | SonyEricsson (USB-Smart) | 0 | 02-20-2006 12:28 |
c975, RadioComm, 900/1800 Band Selection | case_sensitive | Motorola P2k | 0 | 03-29-2005 20:52 |
Manual band Selection for m55 v11 needed. | qqyy | E-Gold Based Phones | 1 | 02-03-2004 08:24 |
SGH N-105 Dual Band Selection | motokia | VLSI, Conexant, Skyworks and Old Models | 0 | 10-02-2003 01:55 |
