Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > GSMServer Products > Smart-Clip
Old 11-21-2006, 18:48   #1 (permalink)
Member: 57254
Thanks Meter: 7
V3r Critical Error De Ad, Repair Anyone ???
Regards !
I try to unlock V3R motorola with TESTPOINT (boot A.30), everything went OK, but when insert battery:
CRITICAL ERROR
DE
AD
Try to repair: repair PDS, and then flash with SC full flash from support, but result is same.
Before that try to restore security zone, but did NOT help.
Any suggestion ??!!
Anyone have tested solution ??!!
Old 11-21-2006, 19:40   #2 (permalink)
ricardoz's Avatar
Member: 124842
Thanks Meter: 11
Originally Posted by jode View Post
Regards !
CRITICAL ERROR
DE
AD
Any suggestion ??!!
i have only same problem v3i pls hlp
Old 11-21-2006, 19:47   #3 (permalink)
Member: 197353
V3r boot 0A.30 - unlock via test point (point V3r) smartMoto choice phone models L7.
TESTED - WORK 10000 %
P.S.
Before battery charged full
Old 11-21-2006, 20:40   #4 (permalink)
ricardoz's Avatar
Member: 124842
Thanks Meter: 11
P.S.
phone is dead we need help to revive only appear
CRITICAL ERROR
DE
AD
on lcd
Old 11-21-2006, 22:29   #5 (permalink)
naderhacker's Avatar
Member: 4365
Thanks Meter: 39
full flash using *.smf file use test point every thing is ok
Old 11-22-2006, 00:55   #6 (permalink)
ricardoz's Avatar
Member: 124842
Thanks Meter: 11
repair pds....ok
full flash .....ok
DE
AD
repai pds....ok
full flash ....ok overwrite boot area
DE
AD
some idea ?
Old 11-22-2006, 10:15   #7 (permalink)
Member: 7368
Thanks Meter: 51
sad, but it's true - flash cheap is dead
motorola often uses defective flash chips programmed at higher voltage
Old 11-22-2006, 14:55   #8 (permalink)
Member: 57254
Thanks Meter: 7
If flash chip is defective, flash write error should appear ??!!
I'm NOT sure that this is HW problem, BUT you never know !!!
Does ANYONE repair this problem on ANY box !!??
Old 11-22-2006, 17:45   #9 (permalink)
Member: 143848
Thanks Meter: 125
yes i have one too with same error can anyone fix ?
Old 11-24-2006, 14:22   #10 (permalink)
NELU-GSM's Avatar
Member: 9411
Thanks Meter: 16
i have same error but mine is full of water.
Old 01-08-2007, 05:17   #11 (permalink)
Member: 425136
Thanks Meter: 16
i need the bootloader 0a.52 please
[email protected]
Old 01-21-2007, 10:06   #12 (permalink)
shafnashaji's Avatar
Member: 46116
Thanks Meter: 4
Hai Guys..
Anyone solved this problem..? I got a phone with this error today..
Iam also trying ..any result i get will post it here..
Thanks.
Old 01-21-2007, 11:32   #13 (permalink)
nonu_don's Avatar
Member: 22538
Sonork: 100.67180
Thanks Meter: 2,252
DE
AD
= DEAD flash chip,, 99% cases need to change flash ic or 1% can be faulty TP resister
Old 01-22-2007, 07:46   #14 (permalink)
Member: 57254
Thanks Meter: 7
How do You damage flash chip by unlocking with SC ???
I'll try with TP resistor. Anyone have VALUE ?
Old 03-26-2007, 22:57   #15 (permalink)
Member: 174853
Thanks Meter: 84
oh my ***, i've made my V3r Critical DE AD Error, has anyone got the same problem and manage to repair it? i just unlock it wit p2k tools and it blink, goes off, then using smartclip i repair pds, full flash using R4515 firmware, mine was R3443U2 it a big mistake because i think it was all the same for V3r
is there anyway we can erase the whole flash chip before flashing the right firmware into the phone using smartclip?
please post your opinion guys...
thx a lot for sharing your experience...
V3r Critical Error DE AD oldcoyoteinc Smart-Clip 2 05-29-2007 16:47
v3r CRITICAL ERROR DE AD ikrash Motorola P2k 1 03-29-2007 21:24
V3r Critical error DE AD Jokerus Ultima Box Light 9 03-26-2007 11:42
V3r Critical Error DE AD after unlock sgpstar Smart-Clip 4 09-07-2006 15:00
V3r Critical Error DE AD MIKES Smart-Clip 12 09-05-2006 23:35
Page generated in 0.26251 seconds with 10 queries
